My reply earlier only pertains to the LED headlamps. If you are ADDING fog lamps because you don’t have them from factory, then you need to add the harness and headlamp switch for them and enable a few more settings in AlfaOBD. If you have halogen factory fogs, and are swapping them for factory LED fogs, it is a direct plug n play swap, but you have to enable the LED fog lamp setting. The LED tail lamps have a 12-way connector on them, whereas the base tail lamps have a 6-way connector, so you’ll have to build little conversion harnesses for them using about $20 in parts. You’ll also need to enable the LED tail light settings for those.
EDIT: Since you already have AlfaOBD, you might as well just get the LED tails with blind spot sensors, and enable that feature too. It’s only a few wires that need to be added and is fairly simple.
