With extra hardware and an AutoAuth sub to unlock the SGW. Dealer will need to do a proxi alignment.Will alfaobd work on the 2026 Ram due to the updated security in the BCM
How do you mount the module? Were there existing holes there?I just completed my install in my 2026 RAM 3500 the cargo camera works but I can not get a image from the side mirrors.
I hope I'm not beating a dead horse. I have read a lot of threads, but I can not find anything related to programming BCM for 2026 HD Rams. I am trying to config the side mirror cameras too the DRVM. Does the programming require a security bye pass cable. Which cable and the location of the plug in if required.
I ordered this one from ddoffroad.com and it works great on my 2025. Easy installation other than: I had to order longer Fakra cables than came with the kit to route them the way that I wanted (from module under driver seat, up B-pillar and along edge of headliner to DRVM and CHMSL) and the right angle FAKRA connector from cargo view cam of my old CHMSL did not fit the different orientation of the cargo view cam connection on the new CHMSL so I had to order a FAKRA extension with a connector that fits. I did,as has been mentioned by others, lose autodim functionality of my outside rearview mirrors. I would like to find out if there's a "open a gateway/ reprogram with alfaOBD/ dealer proxy realignment" process that works to get autodim functioning again.I have tried this set from a company local to me and it works
2019-2026 Genuine Mopar Ram 1500 2500 3500 Digital Rear View Mirror Pl
Description Upgrade to our premium factory OEM Ram Digital Rearview Mirror for a seamless, plug-and-play experience. Designed for effortless installation, this upgrade works just like a factory-installed feature. Simply replace your existing interior rearview mirror and third brake lamp, then...ddoffroad.com
The inputs on the module will only work with the proper cameras. The surround cameras and the DRVM cameras are made by different manufacturers and won’t talk to each other.I ordered this one from ddoffroad.com and it works great on my 2025. Easy installation other than: I had to order longer Fakra cables than came with the kit to route them the way that I wanted (from module under driver seat, up B-pillar and along edge of headliner to DRVM and CHMSL) and the right angle FAKRA connector from cargo view cam of my old CHMSL did not fit the different orientation of the cargo view cam connection on the new CHMSL so I had to order a FAKRA extension with a connector that fits. I did,as has been mentioned by others, lose autodim functionality of my outside rearview mirrors. I would like to find out if there's a "open a gateway/ reprogram with alfaOBD/ dealer proxy realignment" process that works to get autodim functioning again.
Kind of off topic thought that probably doesn't belong in this thread: The underseat module that I installed for the DRVM has additional FAKRA inputs (TRAILER, RHOSM,LHOSM). I do not have the side mirror cameras but I wonder if I could locate the module/surround view camera processor and find where the input from the turn signal activated blind spot cameras or surround side view cameras plug into the module. If I put a FAKRA splitter on the cables from those cameras before they enter the surround view camera module/processor and send a cable from the splitter to the RHOSM, LHOSM inputs on the DRVM underseat module would that allow me to toggle to a split screen 3 camera view on my DRVM (with blindspot view instead of side view camera)? I tried plugging a FAKRA cable from my old CHMSL cargo camera into the TRAILER input on my new underseat DRVM module and still could not get the DRVM to switch views to that by hitting the far left button on the mirror that is supposed to switch screens so I'm guessing it wouldn't work plugging blind spot camera inputs into the side view camera plugs on the module. My DRVM or the module may not support this...
Figures. The cargo view camera in my new CHMSL was different from my existing cargo view camera. When I connected the cargo camera in the new CHMSL from DD Offroad all I got was a black screen on my cargoview. I tried to switch the cargo view camera from my old CHMSL into the new one but it would not fit (cameras had very different shape). I ended up moving the DRVM camera from the new to old CHMSL. The old CHMSL had a mounting spot for the DRVM camera but no hole for the lense so I had to drill a hole for the lens. Not exactl a "plug and play" swap but both cameras are working now.The inputs on the module will only work with the proper cameras. The surround cameras and the DRVM cameras are made by different manufacturers and won’t talk to each other.
Sounds like you had a analog camera and they sent you a digital one. I had that issue when I got my digital mirror from Infotainment. The camera had an ANALOG caartgo camera so I had use the crago cam out of my old CHSML - FARKA connectors are different.Figures. The cargo view camera in my new CHMSL was different from my existing cargo view camera. When I connected the cargo camera in the new CHMSL from DD Offroad all I got was a black screen on my cargoview. I tried to switch the cargo view camera from my old CHMSL into the new one but it would not fit (cameras had very different shape). I ended up moving the DRVM camera from the new to old CHMSL. The old CHMSL had a mounting spot for the DRVM camera but no hole for the lense so I had to drill a hole for the lens. Not exactl a "plug and play" swap but both cameras are working now.
