I have a few NOOB questions about adding the remote start feature to a basic 2020 Ram 2500 Tradesman. Just an FYI - At this point, I have not performed any mods with the OBD at all.
I called my local dealership and they are willing to activate a fob that I bring in (even if the fob I bring in has the remote start and tailgate option on it) for $65. They said they would activate the remote to lock/unlock and start the truck after they received a PIN code from Ram, but since I wasn't buying the fob from them, they would make no guarantees, but it should work if it is an OEM fob. So here come the questions -
Can I just get the dealership to activate the fob first, before performing any mods - such as wiring the sensor from the hood latch to the BCM and manipulating the BCM with the AlfaOBD method? Or do I need to have the wiring completed and modify the options with the AlfaOBD before the dealership activates the remote?
How would they be able to test it without the hard parts installed (unless you put in a restistor/jumper as @Jimmy07 has commented on before) ?
