On the whole, these trucks are very reliable. The lifter failure, while it is concerning, is not a widespread issue. It has gained a lot of attention and notoriety more so because it’s a unique and uncommon type of failure for a Cummins engine when compared to the steadfast reliability the older generation valvetrain demonstrated.
The “typewriter tick” shouldn’t occur on these engines if everything is in spec and functioning correctly. The valvetrain is actually quieter than the previous flat tappet arrangement found on all previous generations of the 5.9 & 6.7 engines. Noise was actually one of the reasons Ram opted to switch the valvetrain over to hydraulic roller lifter. This move reduced the “NVH” (noise, vibration, and harshness) of the powertrain over previous years. Based on the conversations that I’ve had, the trucks demonstrating the “typewriter tick” after an oil change may be demonstrating the initial signs of lifter issues, but that has yet to be conclusively determined. As i mentioned previously in this thread, there is some theory that the light “tick” that is heard could potentially be the hydraulic portion of the lifter assembly reacting adversely to the upper valve movement. The theory involves an inability for the HLA to adequately “cushion” the valve actuation, resulting in a light tap or tick. This is currently something that is under investigation and analysis at the engineering level.
Can’t speak for the other brands, but the move to hydraulic roller lifters in the 2019+ Ram HD’s was done chiefly to reduce the “NVH” of the platform. As a bonus, it eliminated the need for a valve lash adjustment, thus reducing the overall cost of ownership and maintenance requirements. It is my understanding, based on countless conversations I’ve had with multiple people within both companies, that the decision to move to a hydraulic roller lifter design was ultimately made by Stellantis, not Cummins. Cummins’ current B6.7 commercial engines are still the tried and true flat tappet design they have always been.
It’s really not bad enough to warrant offloading the truck. Best thing you can do is keep up on your maintenance, document your service work, and do what you can to minimize any chance of losing your powertrain warranty. If you plan to keep the truck long term, I would recommend just putting some money aside here and there over the coming years. If yours should fail outside of warranty, have the lifters replaced with the flat tappet conversion kit made by Hamilton and then you’re set. Otherwise, run it until it’s out of warranty and then offload it.
I would very much like to do this. However, it takes a lot of time to put one together, and I need worn components to demonstrate the causes of failure. It would be a good video for my YouTube channel. I may try to get one done in the coming months. It’s just difficult to find the free time that’s required to make a quality video.
