Dennis Hobbs here: Add me to the list - towed in 10/03/2024 have all the symptoms of TSB-21-002-23 occurred while towing about 13k 5th wheel. I am orig owner purchased 11/2022. Not ordered bought off new car lot. Miles at the time of failure 19,474 / Date of Manufacture (will provide later) Gears 1-4 slowed to a crawl/ Pulled off interstate just in time / after testing, reverse not working.
My vehicle is
Engine: 6.7L I6 Cummins HO Turbo Diesel Engine
Transmission: 6–Speed Automatic Aisin AS69RC HD Transmission
I would be happy to. Just need all of the following info for the spreadsheet:
1. Date you ordered the truck (if applicable)
2. Date of manufacture (See sticker on driver door for "date of manufacture (Build date))
3. Date you purchased the truck
4. Mileage on odometer at the time of failure
5. Serial Number of failed transmission (see blue stamped metal tag on side of the transmission. It will be something like "2H-2345"
6. Serial Number of replacement transmission (if applicable)
7. Were you towing at the time of failure?
8. Did 1st through 4th gear work?
9. Did reverse work?
10. What date did the transmission fail?
11. When was the truck returned to you after repair?
12. Did your dealer replace the transmission with a new unit or was the failed transmission repaired with parts?
13 Was / Is the truck currently identified under Customer Satisfaction Notification 71A?
