I put that size in the KO2 on +12 wheels on mine no mudflaps and they rubbed just a tiny bit I added a 1" spacer on the coil and it has almost completely gone away
I am picky about rubbing as well
Nice truck! Good to hear 1 inch spacer helped.
Looks great
Post how they are and especially the road noise level.
Decided to take it on a little 60 mile trip today. First time driving on them and have some info for you. I ran the original tires at 50 psi all the way around and I set these to 45 in the front and 40 in the rear. They were a softer ride, more sidewall and less psi I'm sure helped. They handled just like they should, so no complaints there. The road noise was almost non existent, but I think ram did a good job with cabin noise in this truck. Now for the bad news, got a vibration from around 50 up to 75mph. So at least 1 is not balanced.... they came mounted and balanced but I only actually looked for weights on a couple of them the day I put them on. So I hope it's something as simple as 1 didn't get balanced... we will see.
Just picked up my 2024 tradesman 6.4 hemi on Sunday.
All rdy installed some running boards, back side step (note I sheared off a bolt and need to figure a way to remove that see pics), pro clip cell holder, front dash cam. More little mods to come. Anyone have any ideas or tricks to remove this sheared bolt?
Is this a 6 1/2 bed? Also whats the brand? Easy fit?
Finally hooked up the Baja Designs Squadron fog lights. I wired them to AUX 1. I'm glad it was so simple.
Baja designs reverse light kit, rear ID bar, B-post trim, factory fogs and a 1” level.
Did you buy the factory fog lights and trim? I have a tradesman and don't have fog lights. I do have 6 aux switches though. I would like to add them.
I added this to my 2019 2500 6.7 Cummins with the off-road package (anti-slip diff). I think the power wagons and gassers come with them. The diesels don’t seem to and I don’t know why. I was getting bad shudder/hopping when in dirt or slick stuff. This seems to have helped from what I can tell (I have only been in some mild loose gravel so far, more testing to come). Rear end feels more planted for sure in my opinion. It was around $225 from Geno’s (that was the cheapest I could find it)
Power Hop kit:
My 2024 2500 Rebel Cummins has it...
