Hopefully this gets expanded to the earlier years soon!
Correct. This is how the Aisin K1 snap ring issue started and ultimately was expanded, ending up with a full customer satisfaction campaign and an NHTSA investigation.Fellas. Admitting you have a problem is step 1, right?!? Hahaha let’s see what happens. I’m always optimistic.
Am I missing something? I can not see the attachmentI read it as both.
Acknowledge they have an issue and potential build dates
Replace entire DOC / DPF is the fix. But it specifically states it isn’t a proactive repair. Only to be done on trucks under the RSU and within the build dates in question
No I removed the post. Have to wait until it’s released publicly. Shame we have to tippy toe around. But hopefully it will get publicly released soon.Am I missing something? I can not see the attachment
Hang on… tippy toe around who? Someone from Stellantis say something? And if so, why are we complying to suppressing info that IS technically public (anyone can get a subscription to see, and print the tsb). When is it considered public, when NHTSA posts it, usually about a month or two after tsb’s are released?Have to wait until it’s released publicly. Shame we have to tippy toe around. But hopefully it will get publicly released soon.
So I won't get any help with my truck built in April of 22 - what a load of crap - if I am not towing, I can't get beyond 175 miles between regens in the warmer months and 250 in the cooler months. Tired of changing my oil early to avoid fuel dilution and what this fixed.No I removed the post. Have to wait until it’s released publicly. Shame we have to tippy toe around. But hopefully it will get publicly released soon.
To give you the brief synopsis:
Ram released a new TSB 25-005-24 for trucks experiencing P2459 frequent regeneration issues. So they’re finally acknowledging it’s enough of a problem to warrant a bulletin. Hopefully it’ll get expanded. Only applies to 2022 and 2023 model years built between 8/1/22 and 5/1/23 right now.
As I said before, I’m willing to bet it gets expanded.So I won't get any help with my truck built in April of 22 - what a load of crap - if I am not towing, I can't get beyond 175 miles between regens in the warmer months and 250 in the cooler months. Tired of changing my oil early to avoid fuel dilution and what this fixed.
No, no one said anything to me yet. I removed the post preemptively.Hang on… tippy toe around who? Someone from Stellantis say something? And if so, why are we complying to suppressing info that IS technically public (anyone can get a subscription to see, and print the tsb). When is it considered public, when NHTSA posts it, usually about a month or two after tsb’s are released?
Agree.The problem is the wear and tear on the other components while the main issue is not fixed. But progress none the less.
Agree.
Unfortunately, this is the way manufacturing operates today. It isn’t just Ram, it’s a systemic culture in most all of the large corporate industries today. I have a John Deere recall sitting on my desk for my uncles 1025R sub compact utility tractor. There’s a component quality issue with the brake system that can cause it to completely lose its brakes without warning. Deere says “stop use immediately” and schedule an appointment with your dealer for repair. Called my dealer and they’re being told by corporate “no parts currently available to satisfy the recall, expected ship date of parts is mid-October at the earliest.”
They're all too big to care and they’ve all lost sight of the people that helped build their empires.
When you go pick it up, tell them about the TSB that just came out for the 22-23 trucks. It will surprise them that you already know about it and may help motivate them to report higher up that the 2021s have the issue also. That's my plan for when I take mine in next week.mine has been trowing the code as well and fuel in the oil been in dealer 3 weeks now there replacing a map sensor and new air filter and giving it back to me can’t see it fixing the crazy amount of regens but we will see I’ll keep you informed but mine is a 21 so I guess they won’t replace my dpf
do you know the build date of your truck? Curious if its close enough to a 22 to possibly have something in common with a 22. my 21 was a early build had had no issues. and you really dont hear alot of 21's having problems.mine has been trowing the code as well and fuel in the oil been in dealer 3 weeks now there replacing a map sensor and new air filter and giving it back to me can’t see it fixing the crazy amount of regens but we will see I’ll keep you informed but mine is a 21 so I guess they won’t replace my dpf
Mine was delivered in April 2021 after custom ordering it a couple months earlier, and it for sure has the excessive regen issue.do you know the build date of your truck? Curious if its close enough to a 22 to possibly have something in common with a 22. my 21 was a early build had had no issues. and you really dont hear alot of 21's having problems.
do you know the build date of your truck? Curious if its close enough to a 22 to possibly have something in common with a 22. my 21 was an early build had had no issues. and you really dont hear alot of 21's having problems.
