In what department did you change the tyre size please?I measured tire size. Level on top to ground. Use a inch to mm calculator. Multiply MM x 3.142 When I had the 295-70-18 in Coopers they measured 33.7 = 2689mm
Need some help here please to understand how you did it.
How did you work out the tyre size?
Is the tyre size changed in the transfer case or the instrument cluster?
Asking because I am getting rid of the standard tyres on my truck as they are crap and fitting 295/70/18 Maxxis Razr MT811
Same happened to me, the mechanic put all 3 5 litre bottles of Rotella in. I checked it later and same as you ... too full. I took it back and he adjusted it. So the next time I bought the Valvoline Premium Blue in 4 litre jugs at the Cummins online store and after that oil change I used them to fill with the Rotella so he would not overfill it again.Well, had me a senior moment a few days ago. Sooooo I changed my oil and filter. Getting ready to head south in a few weeks. Drained it and added just shy of three jugs of Rotella. 11 and a bit quarts, right? I checked the dipstip and it looked over full but figured the oil was still draining down and let it sit. Next day it was still over filled after sitting overnight. So I drained a quart out went on an errand and after shutting the truck down I waited an hour. STILL over full. Hmmm. Then the gods of enlightenment struck this old brain. In Kanuckistan, the jugs of Rotella are 5 LITERS. NOT 4 quarts. So I overfilled it by over three quarts. Duh. That is what I get for buying oil on both sides of the border. So I need to drain another two quarts out. Some days are just better then others.
Thanx mate.If you have a 2018 or newer you need a security bypass cable or Kaodtech cable , an obd2 programmer then alpha obd2 software (android) or jscan (iphone). then you can adjust the tire size to keep your speedometer correct. View attachment 77203View attachment 77204View attachment 77203
Looks good! Deer are a pain for sure. Wife bunted one with her new Grand Cherokee the other morning in the darkLittle quality time in the shop in preparation of suicidal deer encounters. View attachment 77309View attachment 77310View attachment 77311View attachment 77312View attachment 77313
What is in the box in the very front of the pic and what jugs are behind the transmission liquid pouch to the left ?Not just today, but slowly been picking away at my annual maintenance list, plus a couple goodies, for a few days.
I thought maybe this was goin in a Where Is Waldo direction!It’s a BD 2-Low kit and more ATF since I serviced the transfer case and AS69RC.
