Nice! CO FTWAdded some vinyl stickers to the back glass (yesterday though).
OA
Get some rubber door seals or edging. Maybe the type that has an adhesive strip. Just spit-balling. I know I'm not remembering the other stuff but it's a pretty hard plastic, split to open up on one edge. Someone will pipe in.Any thoughts on what to do about the ugly pinch weld visible beneath the doors?
I have installed AMP powersteps but they disappear when retracted, revealing the pinch weld.
Look this up on Ebay
Have one to sell?
Sell now
Similar Items
See all
Feedback on our suggestions
That stuff will hold in dirt, salt and block the rocker panel drain holes. baaad idea. I tape off, scuff with 3m red pad and spray with matte black spray paint.
. The tape job are up above, block holes for mounting cab steps, etc, the drains are in the low point of the rockers.I was thinking the same as far as holding in the crap but aren’t the rocker drains up above the pinch welds? That lovely tape job they give us on our overpriced trucks.
Sent from me
The Front has a drain tube, but it's not to long. I just use a large spray bottle and put the tube in it and balance it on the front dif/axle.Next question.
Fuel filters front and rear, drain tube(s)?
Thanks for the help I'll be looking for that hose on the front filter.The Front has a drain tube, but it's not to long. I just use a large spray bottle and put the tube in it and balance it on the front dif/axle.
For the rear I just found a hose I had laying around and pushed it on the little nipple and let it drain into a tub/bottle.
i have box of fuel line, i cut off a 2 ft section and slide it over the front tube to drain the filter. rear i gave up on trying. they put the housing right over the driveshaft so i just let the freedom ring cause no matter what it ends up a mess. if i feel like trying to be clean i prop a plastic bin on the drive shaft and do it that way.
Here's what I made. Absolutely clean filter replacement, without a single drop escaping!i have box of fuel line, i cut off a 2 ft section and slide it over the front tube to drain the filter. rear i gave up on trying. they put the housing right over the driveshaft so i just let the freedom ring cause no matter what it ends up a mess. if i feel like trying to be clean i prop a plastic bin on the drive shaft and do it that way.
