LamboTexas
Yesterday...
Added airlift 5000 airbags. Noticed in my towing pic with fiver that I had a pretty good squat. Figured it would be good to level it back out a bit. Install with compressor took about 3.5 hours. Just a quick trip so far, but, feels like the unloaded ride is improved as well.
I went with the ones without them. I read a few reviews that said they were too long and the truck would hit them frequently, causing a harsher ride. Probably would have been fine, but, I wanted to try and soften the ride a bit with them, so, didn't want to have that issue.Do those have the bump stops internally?
Oregon or Virginia? Disregard I saw in pics above you’re in Oregon. I get It now, the passengers stickers... a Hokie from VA.Added some vinyl stickers to the back glass (yesterday though).
OA
Looks good, you should post a night pic too. Looks like you’re a FCA commercial, Grand Cherokee, 1500 Big Horn, 2500...Finally got my Baja Designs, OnX6+, 20" LED - # 4480301 installed behind the front bumper grill. I had to remove the air dam to get access behind the bumper. Most forum guys are removing the air dam to get more clearance and say they like the look better. I'm going to leave mine off for awhile. Not sure but I think I will put it back on as it does serve a purpose and clearance isn't a problem as I'm not off-roading this truck.
Having skinnier arms and little hands with long fingers would have helped a lot. I had to heat and bend a wrench to get the right angle for two little 8mm nuts. Took me about 10 heats and bends to get the right fit. Glad it's over.
This thread asks "what etc today" - this took me more than today
Thanks - you have a good eye except for the 2500, it's a 3500Looks good, you should post a night pic too. Looks like you’re a FCA commercial, Grand Cherokee, 1500 Big Horn, 2500...I’m with you
Oregon or Virginia?
