Towed this to fill this.
Got 15 tons of 57 stone to go in over the pipe.
However about 15’ of trench caved in the rain/ monsoon last night so lots of hand shoveling vs the excavator work.
I know what you mean. It looks like you might be in Las Vegas like me. You should see the registration fees for my 2022 Limited Deisel Dually. WOW
Yep. NLV. I still figure I got off lucky because I had previously plugged in the data on a new 2023 Laramie into the DMV registration estimator and it came up nearly $1400 the first year! Not to mention add the sales tax....
Changed out the 2 fuel filters, cabin filter, then noticed either a transmission leak or a transfer case leak where they bolt together. So either a input or a outputseal I reckon. Degreased and washed the underside to remove the atf/ tc fluid from everything. Dealer can't get me in till April 19th
Yes underneath not able to see all 5 bells on the horn.
Waiting for parts to install Viair 485 c compressor and 3 gal. tank,
those two will go in tool box mounted in bed.
Any thoughts on what to do about the ugly pinch weld visible beneath the doors?
I have installed AMP powersteps but they disappear when retracted, revealing the pinch weld.
