My '22 has 15k on it, roughly half of those miles towing our 10k lb travel trailer and a few hundred hauling a gooseneck at 15k lbs. I couldn't say when or how often it has gone into regen. It's just not something I monitor. All my fuel and DEF has come from various truck stops during our travels and my local Love's when I've needed to fuel locally. My DPF gauge has never read anything other than 0% the few times I've glanced at it, although I haven't had the recent recall done to install the missing sensor so that's likely why. I just haven't seen a need to worry about it since this truck seems to burn DEF at pretty much the same rate as my 2017 did and to be honest I'm getting tired of making trips to the dealer for these silly recalls. Now if they could come up with a actual fix for my cluster/radio preset issues I might reconsider.
The Y43 DPF sensor has no bearing on the DPF gauge.
Also, DEF consumption has nothing to do with DPF soot loading. You should be using a fair amount more DEF with the 22 than the 17 thou since the 22 uses less EGR, which is a good thing.
