Regen
I pulled my air filter out yesterday and vacuumed out the housing and checked the condition of the filter. It’s been 7750 miles since I changed it and it wasn’t anywhere as dirty as the original filter I changed out at 6278 miles. I don’t know if they spray some kind of oil on the original filters or what but the original filter was coated down with something black and looked like grease on it. I’ve not had a soot based regen since I swapped the air filter out. I put the old style AF 27684 FleetGuard in when I changed it. I have been running mine with the top 3 slats out of the AGS shutters for about 6 months but reinstalled them yesterday to see if it makes any difference.
I wondered about those shutters. Keep me updated on that….
yeah they’re definitely incorrect.
The glue strip versions of the Fleetguard AF27684 are a recent thing. Fleetguard subbed their manufacture out to a plant in Mexico, instead of the one in the USA. When that happened, the product changed. This happened somewhere around December 2023. Supposedly they started making them in the states again. View attachment 71711
I will. I also talked with the FleetGuard Rep again about their providing the original style filters again. He said he talked to one of the engineers about them and the engineer said they had gotten those (the ones with the black seal) by mistake. But I still wouldn’t order one anywhere besides Geno’s since they know about the issues. The filter was nowhere near as dirty without the slats in the AGS as it was on the original filter with them in but I’ll see what happens.
I just received a new one from Genos, the color is off compared to the older Fleetguard air filter I have on hand
108 mile trip.
All highway. Unloaded
80mph continuously.
Started out:IMG_6492.jpeg
Ended up:IMG_6493.jpeg
During the trip I saw it increase to about 37% or so, then drop back to 25% a few times. But it never fell below 25%. I’ve made this trip three times in the last seven months. The other two times it was squeaky clean when I got back home.
Do you have any ideas why it didn’t clean out this time? Mine started at 0% and in 15 miles went to 25%. Cut it off at the grocery store and came back out and drove straight back toward home and it jumped to 37% and shortly started regening. So I kept driving until it finished. Were you getting close to having a time based regen ?
I have no idea. It hasn’t been passively regenerating well since the spring weather warmed up. I’m only about 5 hours and 321 miles since the last active regeneration cycle. This truck acted the same way last year. As soon as the weather warms up, it can’t seem to passive regen well and builds soot more quickly
Mine has never been good about passively regening unless I run it over 80 mph. The max speed limit around here is 70 so I hate to chance it for 2or3 hours at a time. Usually I can hook up to my TT and within 20 miles it will be back to zero. I had just done that before I put the AGS slats back in and had it sitting on zero to start. I’m not sure at what speed the AGS opens or if it even closes when towing.
I had no issue with passive regeneration for the past seven months. All winter it was fine. Now it’s not doing it. This truck acted the same way this time of year last year. I’m not sure what causes it.
No, I don’t have any monitors to log or view PID’s.
All I have is a cheap code reader but it does let me record different data points and watch it in real time. I don’t know what the different values should be for different pids but I can watch egt’s and other different things.
With EGR there is not much fluctuation in IAT’s, at least not like a diesel without an EGR.
I noticed mine varying about 10 degrees with varying amounts of egr depending on engine load. The temp would actually go down loading the engine.
It was hard to watch and drive at the same time.
I just watch it for trends, and have on all my diesels. 10° of fluctuation is minimal.
Yes, IAT will decrease as load increases because the EGR flow decreases. That is until the intercooler can't keep up with the increased ambient temp of sustained high boost while pulling a grade at high boost.
For reference, my 05 would run an IAT within 10° of ambient under most conditions, closer to IAT when cruising. On long hard, hot pulls it would get to +30-35° from ambient at most.
If you watch your IAT during a regen when the EGR is closed you can see what it would be like without any EGR.
Today is the first time I’ve tried it. Going to have to get the wife to drive so I can watch it. Her screaming at me while trying to drive and watch it was distracting.
