Yea meant dpf
This is as high as it Gets then clears up
I was referring to where you said burning DEF.
You appear to be only having 24 hour regens.
Yea meant dpf
Your drive cycle is what keeps your DPF clean. You should get many trouble free miles with that type driving.Yea meant dpf
My drive cycle is not nearly as good as yours but I have gotten the 24 hour time based regens for the last 4 regens. I did tow my TT for 50 miles on the last one.
Yea meant dpf
Yesterday i hit the 24 hour mark, went into regen for 12 miles then ended. Went from 20.5 mpg to 19.1 during the process. Before the 24 hour hit my dpf gauge read about 15% or so, but its back to 0. ill be putting another 1000 miles on the truck this week, so see how it goesThis regen hit at the 1200 mile mark.
Our truck is a 2022 3500 SO with just over 11,400 miles (bought new 1 year ago). Over 7000 miles has been towing our fifth wheel. I'm using DEF at a 3.02% rate (just throwing it out there, even though it has nothing to do with regen).
Contacted our dealer and ended up dropping the truck off yesterday. The truck has gone into regen 4 times in 5 weeks. I've learned a lot from reading this forum, and watching some experts on YT. The dealer's tech checked everything on the checklist that is seen on either page 1 or 2 of this thread. His report stated the air filter was new, and is fine (note: I replaced the air filter with one from AutoZone, and it's an STP; so that may be the issue). He also noted that the MAF sensor is the German one (I have the photos), and that Engineering recommends the Chinese part; so it will be replaced under warranty.
As a side note, the very 1st active regen occurred following a 3000 mile road trip, almost all of which was towing, including lots of mountains. The active regen occurred 2 weeks after our return. Unfortunately, I didn't know enough to track things like engine hours and DPF %. I will going forward though.
More than one likely.I’m positive you had an active regen somewhere probably smack dab in the middle of that 3000miles pulling that camper, it runs on a 24hr clock and unless you have other issues it should not have been soot based. I usually keep the DPF gauge up on the Evic so I know when it’s in regen and track it using one of the trip meters.
Right, I just hadn't tracked the info. ThanksEngine hours are displayed on the EVIC.
I have a Mopar filter on order from Geno's. ThanksThese trucks are extremely sensitive to air filters. I would start by swapping in a Mopar or Fleetguard filter and reevaluate.
Anyone know what the warranty is on the DPF? Some places say 3yr/36k, some say 5yr/50k (Federal Emissions Warranty) and some say 8yr/80k (Federal Emissions Warranty). My 2022 RAM 3500 goes into passive Regen every 75-150 miles. I leave the DPF gauge up so I know when it goes into passive Regen every time and always let the cycle complete every single time so I've never had the P2459 code but I'm sick of it. I have used Archoil at every fill up since new, change the engine air filter (no glue strips) every 6 months, and had the correct MAF sensor installed. I'm at 38K miles and because of the TSB may just stop paying attention to the passive regens, let the DPF fail, get the P2459/CEL and have the DPF replaced but want to make sure it's covered.
I’ve wondered the same if anyone knows for sure. Here’s the ChatGPT response:Anyone know what the warranty is on the DPF? Some places say 3yr/36k, some say 5yr/50k (Federal Emissions Warranty) and some say 8yr/80k (Federal Emissions Warranty). My 2022 RAM 3500 goes into passive Regen every 75-150 miles. I leave the DPF gauge up so I know when it goes into passive Regen every time and always let the cycle complete every single time so I've never had the P2459 code but I'm sick of it. I have used Archoil at every fill up since new, change the engine air filter (no glue strips) every 6 months, and had the correct MAF sensor installed. I'm at 38K miles and because of the TSB may just stop paying attention to the passive regens, let the DPF fail, get the P2459/CEL and have the DPF replaced but want to make sure it's covered.
That's what I found too and online it says the DPF is covered by that warranty. I'll call RAM to try to get confirmation tomorrow.The warranty supplement for my 2022 lists the federal emissions warranty as 5yr/50K miles.
For a Ram 2500 with a diesel engine, the Diesel Particulate Filter (DPF) falls under the Federal Emissions Warranty, which typically covers emissions-related components for 8 years or 80,000 miles, whichever comes first.
However, some states with California emissions standards (e.g., CA, NY, MA) may have extended coverage under their specific emissions regulations. You can verify your exact warranty details in your Ram warranty booklet or by checking with a dealership.
My understanding is that there are two types of regen. The "active" regen is when the center display says "exhaust regen in progress, continue driving" and the "passive" regen is supposed to take place every 24-25 hours of drive time and unless you're watching the DPF gauge you're not notified it's happening. Because most guys don't watch that gauge the cycle doesn't always complete, the DPF clogs and fails and the CEL comes on, throwing the P2459 regen frequency code.
