gprguy
I want to install a second 22 gal tank on my 2023 RAM 3500 C&C. I'd like to keep the rear tank as the primary, transfer fuel from the mid tank using an AUX switch and have both fuel gauges with the range guesstimator. Looks like the retail price would be in the $1200 range.
I ASSuME that I can
1. just leave the rear pump/sender wiring alone,
2. do the VehConfig 3 and ECUConfig 4 but not the CBC config I/O,
3. run the output of the mid pump to the aux? input on the rear pump,
4. wire up the fuel sender and an aux switch to the mid pump.
Anyone see a big error in this?
I can think of a few issues, but they probably aren't insurmountable.
I don't know for sure if the resistance/output voltage from the midship fuel tank and the rear fuel tank senders is the same. The modules are different (likely because the height of the tanks are different) but there could be something else different. I think they are the same as I've been running some tests but no guarantees.
Brake line should be fine since you have a 3500, it should go through the crossmember. However if the fuel lines to the rear tank go under the crossmember (they would if it was a 4500/5500, not positive on 3500), you will have to replace those and there isn't a factory configuration that would work. That said they are standard quick connectors, I imagine you should be able to make some that would fit. I think you can buy those ends in AN compatible fittings and make your own lines at home. You'd need to make 3 - the vapor line from the frame to the rear tank (which I think is 5/16" on both ends), the transfer line from the output of the midship pump (which may be 3/8" but I am not positive) to the aux port on the rear tank (which I think is 5/16"), and then the main fuel line from the frame to the rear pump (which is the bigger size, probably 3/8"). Part of me thinks making the lines may be cheaper and easier than going the Mopar route..
If you want me to do some measuring on those fitting sizes I can do that easily enough.
You can move the cap off of the rear tank's aux port to the midship vapor port to cap it off.
And yeah, you'd need to wire fuel sender 2 (the midship in your case) into the dark blue/grey wire (pin 8) on the front side of the XY965A (blue handle) wiring connector, as well as tap into the black fuel sender return (pin 7). If you want to operate it manually with the aux switch you can just run an aux output to the midship transfer pump and put a 20 amp fuse in the aux PDC, should be good to go at that point.
That's all that comes to mind - if you wanted it to automatically transfer I can imagine the computer might not like the tanks being reversed, but since you are doing it manually I think it's possible provided the fuel senders have the same ranges.
