gprguy
Probably overdue for an update - the theme lately seems to be slowly but surely. The bike mount is coming together, I hope to have it done enough by the weekend that I can move on to the box.
I think I'm on maybe revision 3 of trying to mount the e-bikes. Part of the problem is we have folding bikes and there just isn't a mount out there that I've seen for a folded bike. In the end I decided I need a way to secure the rear wheel and a way to clamp the seat post. I may make a little pocket for the stand/loop that it sits on while folded but that can happen later. I'll probably add some straps later too.
So for the wheel mounts I started out with these from Swagman, I've had good luck with their stuff in the past.
All I care about is the "tray" and ratchet strap, the rest is to mount to one of their racks and it's gotta go. Coulda sworn I took a picture of the mount hacked/ground off, but apparently not. Next up, I need a way to mount them down to the sliding tray. Arts and crafts time:
That should do.. Transfer it to steel, cut it out, bend it up:
Tack it into place and it's looking pretty good to me.
Tomorrow I'll finish welding them, get some rivnuts installed, and they should be good to go other than getting them re-coated. Then I'll be able to start on the uprights for the seat post clamps.
In parallel I've managed to find a couple of used wheels. My truck came with the steel rear inners and no spare, so I decided to find some aluminum rims to use as the inners and I'll keep the steel ones as spares. The 4500/5500 aluminum rims are a bit tricky to find. The older model years look to have used genuine Alcoas with 8 holes, whereas the trucks these days use a knockoff with 10 holes that are chamfered. Finding wheels that are for sure 10 hole and not the older style takes some looking, a lot of the junkyard and takeoffs are the old 8 hole design.
New they are nearly a grand a piece, but I found them at https://factorywheelwarehouse.com/g...ram-4500-ram-5500-factory-oem-wheels-and-rims for a little over $300 shipped. They are used but I am very happy with the quality. They measured out as round and true and I only have a couple small scuffs to fix before they go to powder coat.
I also ordered some TPMS sensors, hopefully that will work as expected on the 4500/5500.
