gimmie11s
Sounds like he pegged you
I like the womens, not the menses
I agree it’s more fun when a woman does itI like the womens, not the menses
Too bad you guys had to sidetrack my thread with your childish insults and idiotic posts that had nothing to do with my original question. It’s morons like you that are driving people away from forums to using Facebook groups instead. No wonder the owners of this forum don’t want to invest in making this site work any better.
Holy smokes thats just wrong! hahahaha
Maybe you don't have enough pin weight?
I have not weighed the set up. Probably should. Was never an issue with my previous Ram. 5er sits level on the truck and nothing else has changed. All my storage is up front.Maybe you don't have enough pin weight?
Do you have the 2500 air ride?I have not weighed the set up. Probably should. Was never an issue with my previous Ram. 5er sits level on the truck and nothing else has changed. All my storage is up front.
I have a 2022 2500 ctd ccsb. No factory air ride. I added airbags and compressor trying to help the sway. Truck does have the Carli 2.5” level kit with Fox shocks. Also, I’m running 285/75/R18 ridge grapplers. (35’s). Last tow I set tires to 60psi and bags to 55psi. Both higher than any previous tow. Didn’t seem to make a difference.Do you have the 2500 air ride?
Then its likely the trailer…. Is the trailer level and tires aired up properly?I have a 2022 2500 ctd ccsb. No factory air ride. I added airbags and compressor trying to help the sway. Truck does have the Carli 2.5” level kit with Fox shocks. Also, I’m running 285/75/R18 ridge grapplers. (35’s). Last tow I set tires to 60psi and bags to 55psi. Both higher than any previous tow. Didn’t seem to make a difference.
Since the truck/trailer doesn’t sway with the boat I am more inclined to think it’s a trailer issue with the 5th wheel, but I would verify everything is tight and properly setup on the hitch.
Check the pin weight distribution. Level doesn’t mean it’s adequate pin weight.
Do a good inspection of the suspension and axles. Look for broken springs, worn bushings,
Yes trailer sits level. Had to flip the axels with the new taller truck to make that happen. And yes tires are always checked and aired to correct psi before each trip. Going to pull the wheels and tires and inspect all the suspension hardware. Might just replace all the components while I’m at it. Thanks for fall the inputThen its likely the trailer…. Is the trailer level and tires aired up properly?
When you *flipped* them you mean welding new spring perches on the top side of the axle tube not just flipping the axle under the springs right?Yes trailer sits level. Had to flip the axels with the new taller truck to make that happen. And yes tires are always checked and aired to correct psi before each trip. Going to pull the wheels and tires and inspect all the suspension hardware. Might just replace all the components while I’m at it. Thanks for fall the input
Yes. New spring perches, u bolts and plates. Was done correctly. Nothing changed on the alignment at all. Used bolts and spacers to align the new perches with the old ones before welding.When you *flipped* them you mean welding new spring perches on the top side of the axle tube not just flipping the axle under the springs right?
Gotcha. I’m guessing most of it is due to the added height. Wondering if helper springs or those sumo helpers would help in the 5erThere shouldn’t be any additional movement on an AUH vs a standard hitch when going down the road.
It may articulate more on uneven surfaces, but that’s shouldn’t happen normally.
The added movement could be due to the higher CG of the 5th wheel now.
