The flat glass on passenger side takes bit of getting used to. I switched from normal to tow mirrors on my last truck and it was a big change as a driver and took a bit of learning curve to figure out exactly where cars were relative to the back of my truck (even though I was already familiar with the truck).
The issue I think most people have with the Ram tow mirrors is that when folded down for normal driving, the convex mirrors are “facing the wrong way”…in that the field of view is mostly vertical which doesn’t really help much. Yes you can adjust them to nearly eliminate blind spots, but being a big, tall truck, it is easy for a car to nearly disappear next to you, or be in a spot you will be in when you change lanes. I think these “slightly” convex/wide angle mirrors will help give a “bigger picture” that makes it easier to see everything going beside and Behind you in a quick glance. I will May even try just the passenger side only first, because that would be more “normal” like most passenger cars.
