Not anything done to my Ram but For my Ram
Converting my dump trailer to adjustable 5thwheel from a fixed terrible hight 5thwheel , can also use for GN too
It always sat terribly nose high and if i had air in my bags on the hitch (3” of lift) it was lifting the front axle off the ground so i gathered some old material drops from around the shop to change it
Here is a bad picture but just what i started with
Drilled some adjustment holes 8” worth of adjustment
Cut off the old king pin and turned it down to a 10” plate from the large square 14x12 plate it was and tacked it on
Here is the tacked up assembly 49” lowest setting
Here is still just tacked but how it sits The trailer was on higher ground thats why it looks nose low but on the shop floor it was 1” nose high so when loaded it would be level
