It's 4'' on the dieselI thought the factory exhaust was 3.5”, but it looks like it fits well. Do you have a CTD? Maybe the exhaust size is different than Hemi.
What’s that hitch step?Installed RG mud flaps today.
How do you like the King shocks? Which ones did you get and were they by Thuren? I am debating about order a full set but wanted to get real world feedback. Everyone tells me that these trucks ride great but I can only imagine it gets better with a set of proper King's on itInstalled the black tip.
I had a similar problem with my 2500. My door wasn't opening as much as the door frame opening. I was able to adjust the upper limit of the garage door to give me enough room for the truck to fit without hitting the bottom of the door.Pulled mine in the garage as far as I could for an oil change.
If the rear tires went up the bump into the garage, I wouldn’t clear
View attachment 24645View attachment 24646View attachment 24647
Bought this Patriot Stealth tonneau cover during the summer and just got to installing it.
Mine fits as is with plenty of clearance BUT I’ve been eyeing a topper and the “j” arm that connect the door to the track mechanism has me worried!Pulled mine in the garage as far as I could for an oil change.
Get a jackshaft opener and have your topper too!Mine fits as is with plenty of clearance BUT I’ve been eyeing a topper and the “j” arm that connect the door to the track mechanism has me worried!
I had to modify my J arm because it scratched the roof of my truck last time I had it in when I added the 1” lift. The J arm is two piece and had some excess hanging down until I cut it down.Mine fits as is with plenty of clearance BUT I’ve been eyeing a topper and the “j” arm that connect the door to the track mechanism has me worried!
I’ll look into that, thanksGet a jackshaft opener and have your topper too!
Mine clears everything now but I obviously don’t have a cap and eyeballing it, the arm looks like it would be close right as the door closes or starts to open.I had to modify my J arm because it scratched the roof of my truck last time I had it in when I added the 1” lift. The J arm is two piece and had some excess hanging down until I cut it down.
Its a Go Rhino # D360TWhat’s that hitch step?
Any complaints with it being 2 inch like rattling and are you using the adapter?Its a Go Rhino # D360T
I bought it for my Power Wagon and transferred it over to the Dually. Kinda keeps people off my ass in a parking lot too.![]()
Been looking at those for my dually....how do you like them?Installed RG mud flaps today.
Clever of them putting that knob on there to take care of the rattleDefinitely have to use the adapter. There is a 2" threaded knob with a 4" or so straight bar on the bottom that you tighten to the receiver and that stops any movement. The only other issue is that you have to turn off the rear sensors on the bumper.
