RamThis2500
Fixed. Sorry about thatIt says Video unavailable because it is private.
You got me on that one. I don’t know where the switch would be in that situation, and I can’t find one optioned like that on autotrader or anything like that to see. It’s definitely possible to configure a CTD 2500 with the off road package and manual t case (at least on the build site), so it should be possible. On the parts catalogs, there’s only two available transfer case switches for the 6.7- with or without. There’s only one cubby part number for that location with the manual t case. There’s no lower switch banks that have sales code BHN in the description, or radio bezel (AC/Heater controls) that have that sales code either. The only thing I can think is if it’s in the radio settings or EVIC settings, with ECU 3: Hill descent switch present not being set, or something along those lines. If that’s the case, and can be confirmed somehow, a dedicated switch for the feature might not be needed to get hill descent control to work?Any chance you can dig up a Diesel with manual case?
Or is that switch on the radio panel?
I just tried to build a '21 2500 with the Cummins and off road package and it automatically includes the Electronic transfer case.You got me on that one. I don’t know where the switch would be in that situation, and I can’t find one optioned like that on autotrader or anything like that to see. It’s definitely possible to configure a CTD 2500 with the off road package and manual t case (at least on the build site), so it should be possible. On the parts catalogs, there’s only two available transfer case switches for the 6.7- with or without. There’s only one cubby part number for that location with the manual t case. There’s no lower switch banks that have sales code BHN in the description, or radio bezel (AC/Heater controls) that have that sales code either. The only thing I can think is if it’s in the radio settings or EVIC settings, with ECU 3: Hill descent switch present not being set, or something along those lines. If that’s the case, and can be confirmed somehow, a dedicated switch for the feature might not be needed to get hill descent control to work?
Not that I trust the build site, but you can build it like this:I just tried to build a '21 2500 with the Cummins and off road package and it automatically includes the Electronic transfer case.
Stupid Question on the 68368375AF ... There are 4 different ones pictured ... The #4 has the front, rear and unlock axels options ... Anyone know, or can link to a post for adding the OEM axel lockers? I have a 19 Big Horn with an open diff that I was looking at swapping an LSD into, but this may be something fun to do just because but I cant seem to find anything on my search attemptsYo Chester!
Try this....68368375AF. I was looking to put that shifter in my 2019 and was told that it won't work because it is for a 2021. This is the vin# that I used and should work for you. 3C6UR5CJ4MG543966.
Oh yeah and by the way , that shifter you are looking for costs around $250.00
You would need a whole wiring harness swap to even have a hope of getting that to work.Stupid Question on the 68368375AF ... There are 4 different ones pictured ... The #4 has the front, rear and unlock axels options ... Anyone know, or can link to a post for adding the OEM axel lockers? I have a 19 Big Horn with an open diff that I was looking at swapping an LSD into, but this may be something fun to do just because but I cant seem to find anything on my search attempts
Yeah i think that a LSD is just easier route than trying to get power wagon lockers. I know lots of people have said it, but its a shame they dont make things more customizable on these trucks. I dont get why they push to order it that way instead of being like a computer where you can plug and play (mopar components into a mopar).You would need a whole wiring harness swap to even have a hope of getting that to work.
I wish that they were more like Ford in the rear locker respect.... Ford tosses electronic locking rear differentials around like candy to children. Ram acts like a locker is some higher power only deemed available in the PW/TRX world. You have to look to find an F-150 that doesn't have a pull to lock 4x4 button.Yeah i think that a LSD is just easier route than trying to get power wagon lockers. I know lots of people have said it, but its a shame they dont make things more customizable on these trucks. I dont get why they push to order it that way instead of being like a computer where you can plug and play (mopar components into a mopar).
Ah well I guess
I have an Alfa OBD II MX+. Is there anything else that I need to program my truck? I am wanting to add the hill descent control switch on my truck.Could not find this anywhere. So I took a chance today in alfaobd and had success. So I thought I'd post it here.
Adding Hill Descent
Switch part number- 68370837AD $52.46 @ MyMoparParts ( Link attached to Part # )
Alfaobd settings-
* VehConfig 1: Hill Descent Feature Present
* ECUConfig 3: Hill Descent Switch Feature Present
Completed on 2020 2500 6.7L 4X4 w/o off road package
3/24/21
Thanks
2021 Ram 2500 6.7 CumminsYou need the security bypass cable.
What model/engine truck?
Did you need the 4 digit pin to add Hill Descent Control?Could not find this anywhere. So I took a chance today in alfaobd and had success. So I thought I'd post it here.
Adding Hill Descent
Alfaobd settings-
3/24/21
So I finally had a chance to test mine and I think it worked? I put the truck in 4 low and pressed the button and the truck held 1 mph but nothing came up on the evic... I also went brain dead when I tried to set the speed. I kept trying to use the cruise control and I remembered that to set it in my wife's jeep you set it with the gear selection.Roger that.
Just checking because it doesn't work on my 3500.
No it did not, that was the other part that had me confused. I am going to attempt to use it when I can but there aren't many hills by me steep enough to test it.Did the button stay lit?
Can you check again if you get a chance and check if you can control the speed?
Mine will say it isn't available and stay there for a few seconds if I try to use it not on a hill.Mine flashes the button LED, dash display about speed selection, then "not available," almost too rapidly to see. The LED is off. Second press does the same. Third and subsequent press nothing at all. Have to restart the truck to reset it.
