The 2026 Ram Heavy Duty lineup looks simple at first glance, but choosing the right Ram 2500 or Ram 3500 can get confusing fast. Between multiple engines, wide-ranging towing and payload ratings, new trims like Warlock and Black Express, and dozens of cab and bed configurations, small decisions can have a big impact on how the truck actually works for you. This 2026 Ram Heavy Duty buyer’s guide breaks everything down clearly so you can choose the right setup the first time. For 2026, Ram keeps the core of its heavy-duty trucks largely unchanged after a major overhaul in 2025 that introduced the updated high-output 6.7-liter Cummins diesel, an eight-speed automatic transmission for Cummins-powered trucks, and a refreshed interior with an optional 14.5-inch UConnect screen and new towing technology. This year is best described as a light refresh, highlighted by two new value-focused trims, updated GVWR certifications that affect payload ratings, and subtle lineup refinements rather than major mechanical changes.
Quick takeaway: If you’re shopping for a 2026 Ram 2500 or Ram 3500, the right trim, engine, and configuration matter far more than the badge on the hood — especially for towing, payload, and daily usability.
Table of Contents
2026 Ram 2500 Black Express Crew Cab 4×4. (MoparInsiders).
What’s New for 2026
New Ram 2500 Black Express : a value-focused appearance package built from Tradesman (with a starting price of $55,195 including destination).
New Ram 2500 Warlock : the first HD Warlock, positioned as an off-road value trim (with a starting price of $58,625, including destination). Hardware highlights include an anti-spin rear differential, Bilstein shocks, underbody skid plates, and 34-inch all-terrain tires.
GVWR changes: select heavy-duty models increase GVWR by up to 850 lbs due to revised testing/certification procedures (this can move payload ratings).
Powertrains carry over: 6.4L HEMI V8 and 6.7L Cummins HO remain the two engine choices for the lineup (availability depends on trim).
Quick takeaway: If you’re comparing a 2026 truck to a 2025, don’t assume the payload/towing numbers “should” match. Always cross-check the configuration in the
2026 towing charts .
Ram 2500 vs Ram 3500: Which Heavy Duty Truck Should You Buy?
Quick answer: Choose the Ram 2500 if you want better ride comfort and don’t need maximum payload. Choose the Ram 3500 if towing or hauling heavy loads is the priority.
At a glance, the Ram 2500 and Ram 3500 look nearly identical, but they’re engineered
for different jobs. The 2500 leans toward ride comfort and everyday usability, while the 3500 is built
first and foremost for maximum payload and trailer weight. The differences go beyond badges and affect
suspension design, axle choices, and how much weight the truck can safely handle.
Category
Ram 2500
Ram 3500
Primary role
Heavy towing with better ride comfort
Maximum towing and payload capability
Rear suspension
Five-link coil spring (air suspension available)
Leaf spring (supplemental air suspension available)
Max towing (diesel)
Up to 20,000 lbs
Up to 36,610 lbs
Max payload
Up to 3,930 lbs
Up to 7,590 lbs
Rear wheel options
Single rear wheel only
Single rear wheel or dual rear wheel
Ride quality (unloaded)
Smoother, more compliant
Stiffer, especially when empty
Best for
Daily driving, travel trailers, and fifth-wheels within limits
Large fifth-wheel and gooseneck trailers, heavy payloads
In simple terms, the Ram 2500 is often the better choice if your truck doubles as a daily driver or family vehicle. The Ram 3500 makes more sense if your trailer or cargo regularly pushes weight limits and you want an extra margin built into the chassis.
6.7-liter CUMMINS turbodiesel I6 engine. (Ram).
Powertrains Overview
Engine
Horsepower
Torque
Transmission
Notes
6.4L V8 HEMI (Upgrade HD Engine)
405 hp
429 lb-ft
8-speed auto (8HP75-LCV)
Higher payload configurations typically start here; tow ratings vary widely by axle ratio and cab/bed.
6.7L I6 Cummins HO Turbo Diesel
430 hp
1,075 lb-ft
8-speed TorqueFlite HD auto
High tow ceiling on 3500; available broadly across trims, but not on Power Wagon . For the 2027 model year, the Power Wagon does get the Cummins as an option.
In plain English: the gas 6.4L is the simpler, cheaper path to a heavy-duty truck, and it can deliver the best payload numbers in the right configuration. The Cummins HO diesel is the tow monster in this lineup, but its weight can reduce payload, depending on how you spec it (that’s normal for heavy-duty diesels).
Capability Overview
Towing and payload are rated by configuration. Cab, bed, drivetrain (4×2 vs 4×4), axle ratio, and, in some cases, equipment groups can move the numbers. Use the headline ratings as a starting point, then confirm your exact build in the detailed charts.
Quick takeaway: If you tow heavy often, the “right” truck is usually a 3500 diesel spec’d to match your trailer type. If you’re more payload-focused (tools, bed loads, slide-in campers), the “right” truck is often a 3500 gas or a carefully spec’d 2500 gas, depending on your real weights.
Maximum towing and payload (headline reference)
Model
Engine
Max Towing (lb)
Max Payload (lb)
Where it comes from
Ram 2500
6.4L HEMI
Up to 17,840
Up to 3,930
Example: 2500 4×2 Regular Cab 8′ box shows 3,930 payload and up to 17,840 max trailer rating depending on axle ratio.
Ram 2500
6.7L Cummins HO
Up to 20,000
Varies (example below)
Multiple 2500 configurations list a 20,000-lb max trailer rating in the 2026 charts.
Ram 3500
6.4L HEMI
Varies by configuration
Up to 7,590
Example gas 3500 DRW configurations show 7,590 payload ratings.
Ram 3500
6.7L Cummins HO
Up to 36,720
Example: 3500 Big Horn/Lone Star 4×4 Reg Cab 8′ DRW shows a 45,000 GCWR and 36,720 max trailer rating.
Why trims and configurations matter
2500 vs 3500: 2500 uses a coil rear suspension for ride comfort; 3500 uses leaf springs and can be spec’d for much higher payload and higher tow ceilings.
Diesel vs gas: Diesel usually wins towing and low-speed pulling; gas often wins payload (because the engine itself is lighter).
4×4 penalty: 4×4 hardware adds weight, often reducing payload compared to 4×2 trucks.
Axle-ratio changes in towing: The charts show how the same truck can have very different ratings depending on axle ratio.
Dimensions (Cabs, Beds, Exterior, Interior)
Quick takeaway: Regular Cab and 8-foot beds maximize work utility and often towing-friendly packaging, while Mega Cab prioritizes rear-seat comfort. The 3500 adds key SRW vs DRW differences in width and stance.
Bed dimensions (Cargo Box)
All measurements below are OEM-published cargo box dimensions.
Nominal box size
SAE volume (cu ft)
Length at floor (tailgate closed)
Cargo width
Between wheelhouses
Depth
Tailgate opening width
6’4″ box (Crew or Mega)
57.5
76.3 in
66.4 in
51.0 in
20.1 in
60.4 in
8’0″ box (Regular or Crew)
74.7
98.3 in
66.4 in
51.0 in
20.2 in
60.4 in
Exterior dimensions — Ram 2500
Configuration
Drivetrain
Wheelbase
Overall length
Overall width
Overall height
Ground clearance
Turning diameter
Regular Cab 140.5-in WB, 8′ box
4×2
140.2 in
232.0 in
83.5 in
78.0 in
13.0 in
45.4 ft
4×4
140.2 in
232.0 in
83.5 in
80.2 in
13.1 in
45.5 ft
Crew Cab 149.5-in WB, 6’4″ box
4×2
149.0 in
238.8 in
83.5 in
78.2 in
11.1 in
47.9 ft
4×4
149.0 in
238.8 in
83.5 in
80.2 in
13.1 in
47.9 ft
Crew Cab 169.5-in WB, 8′ box
4×2
169.0 in
260.8 in
83.5 in
78.1 in
11.1 in
53.5 ft
4×4
169.0 in
260.8 in
83.5 in
80.1 in
13.1 in
53.5 ft
Power Wagon / Rebel Crew Cab 149.3-in WB, 6’4″ box
4×4
149.3 in
238.8 in
83.4 in
80.9 in
14.2 in (PW) / 13.3 in (Rebel)
48.2 ft
Mega Cab 160.5-in WB, 6’4″ box
4×4
160.4 in
249.9 in
83.5 in
80.1 in
13.1 in
51.2 ft
Exterior dimensions — Ram 3500 (SRW vs DRW differences)
Configuration
Drivetrain
SRW/DRW note
Wheelbase
Overall length
Overall width
Overall height
Ground clearance
Turning diameter
4×2
SRW or DRW
140.2 in
232.0 in
83.5 in (SRW) / 96.5 in (DRW)
77.8 in (SRW)
11.2 in (SRW) / 10.6 in (DRW)
45.4 ft
4×4
SRW or DRW
140.2 in
232.0 in
79.5 in (SRW)
13.3 in (SRW) / 12.4 in (DRW)
45.5 ft
4×2
SRW or DRW
169.1 in
260.8 in
78.4 in (SRW) / 77.1 in (DRW)
11.2 in (SRW) / 10.2 in (DRW)
53.6 ft
4×4
SRW or DRW
169.3 in
260.8 in
78.4 in (SRW) / 79.3 in (DRW)
11.5 in (SRW) / 12.3 in (DRW)
53.7 ft
4×4
SRW or DRW
160.4 in
249.9 in
78.5 in (SRW) / 78.9 in (DRW)
Varies by SRW/DRW
See OEM table
Interior dimensions (by cab)
Measurement
Regular Cab (Front)
Crew Cab (Front)
Mega Cab (Front)
Crew Cab (Rear)
Mega Cab (Rear)
Headroom
39.8 in
40.9 in
40.9 in
39.8 in
40.3 in
Legroom
40.9 in
40.9 in
40.9 in
40.2 in
43.1 in
Shoulder room
65.9 in
65.9 in
65.9 in
65.6 in
65.6 in
Hip room
62.9 in
62.9 in
62.9 in
62.7 in
62.8 in
Interior volume (by cab)
Cab
Front volume (cu ft)
Rear volume (cu ft)
Regular Cab
62.5
NA
Crew Cab
63.9
60.7
Mega Cab
63.9
66.0
Understanding the Trim Lineup
Think of the 2026 Ram Heavy Duty lineup as three lanes: work trucks , comfort-forward daily/tow rigs , and off-road specialty builds . The hard part isn’t picking the “best” trim. It’s picking the trim that matches how you actually use a heavy-duty truck.
For many buyers, the smartest move is choosing the configuration first (2500 vs 3500, diesel vs gas, cab/bed), then picking the trim that gives you the interior and tech you actually want. A loaded Big Horn or Laramie can be a better real-world fit than stretching for a luxury trim if the extra features don’t matter to you day-to-day.
Trim-by-Trim Deep Dive
2026 Ram 2500 Tradesman Crew Cab 4×4. (Ram).
Tradesman
Starting MSRP: $46,485 (2500) / $47,785 (3500)
Tradesman is the foundation of the Ram Heavy Duty lineup. This is the trim for buyers who care about
capability, durability, and price more than chrome or luxury finishes. It’s the most flexible starting
point for work trucks, fleets, and owner-operators who want to spec towing and payload first and add
comfort only where it matters.
Key standard features
6.4L HEMI V8 with 8-speed automatic transmission
LED headlights and taillamps
Uconnect 5 infotainment system
Trailer brake controller
Durable vinyl or cloth seating (configuration dependent)
Major available options & packages
Package
What it adds (summary)
Bed Utility Group
LED bed lighting, deployable bed step, spray-in bedliner
Fifth-Wheel / Gooseneck Prep Group
Factory tow prep hardware for heavy trailers
Safety Group
Expanded driver-assist features beyond base safety equipment
Power Wagon Equipment Group
Give you all the Power Wagon hardware on the Tradesman trim. Suspension, winch, lockers, skid plates, fender flares, etc.
Back to top
Black Express
Starting MSRP: $52,600
Black Express is built for buyers who want a Tradesman-based truck that doesn’t look like a fleet special.
It’s a value-focused appearance trim that keeps the Heavy Duty fundamentals intact while adding visual
upgrades that make it feel more personal without a big jump in price.
Tradesman mechanical and capability foundation
Black exterior accents and wheels
LED lighting
Package
Bed Utility Group
Improved cargo management and lighting
Heavy-duty trailer compatibility
Back to top
2026 Ram 2500 Warlock Crew Cab 4×4. (MoparInsiders).
Warlock
Starting MSRP: $56,325
Warlock is the new off-road entry point into the Ram Heavy Duty lineup. It’s aimed at buyers who need
a tougher stance and trail-ready hardware for job sites, snow, and rough terrain, but don’t want to
pay Rebel prices.
4×4 drivetrain only
Anti-spin rear differential
Bilstein shocks
Underbody skid plates
Package
Safety Group
Advanced driver-assist technologies
Tow Technology Group
Enhanced cameras and trailer guidance features
Back to top
2025 Ram 2500 Big Horn Night Edition Crew Cab 4×4. (Diana Rhoades).
Big Horn / Lone Star
Starting MSRP: $50,480 (2500) / $51,780 (3500)
Big Horn (Lone Star in select markets) is the volume trim for Ram Heavy Duty. It’s designed for buyers
who want a more comfortable daily driver while keeping serious towing and payload capability.
With the right packages, it can be configured to feel nearly as premium as higher trims.
Cloth seating with upgraded interior materials
Uconnect 5 system with larger touchscreen availability
Chrome exterior accents
Power accessories and added storage
Package
Big Horn Level 1 / Level 2
Progressively adds comfort, tech, and interior upgrades
Trailer reverse guidance, additional cameras
Safety Group
Expanded driver-assist systems
Back to top
2025 Ram 2500 Laramie Sport Crew Cab 4×4. (HDRams).
Laramie
Starting MSRP: $62,185 (2500) / $63,485 (3500)
Laramie is the sweet spot for buyers who use their Heavy Duty as both a work tool and a daily driver.
It delivers a noticeably more upscale interior and broader tech availability without jumping all the
way to full luxury pricing.
Leather-trimmed seating
Larger Uconnect touchscreen availability
Premium interior materials and trim
Power-adjustable front seats
Package
Safety Group
Advanced driver-assist features
Enhanced towing cameras and trailer systems
Night Edition
Back to top
2025 Ram 2500 Rebel Crew Cab 4×4. (Ram).
Rebel
Starting MSRP: $69,680
Rebel is the balanced off-road Heavy Duty. It’s for buyers who want real trail capability and aggressive
styling but still plan to tow and daily-drive their truck. Rebel sits between the value-focused Warlock
and the extreme Power Wagon.
4×4 drivetrain
Off-road suspension tuning
Unique Rebel exterior and interior styling
All-terrain tires
Package
Rebel Level 1 Equipment Group
Upgraded interior materials and tech features
Advanced trailer assistance features
Back to top
2026 Ram 2500 Power Wagon. (Ram).
Power Wagon
Starting MSRP: $72,880
Power Wagon is the most off-road-capable production Heavy Duty pickup Ram offers. It’s built for buyers
who prioritize trail performance, control, and recovery gear over maximum towing numbers. This is a
specialty tool, not a tow-rating champion.
4×4 only
Electronic locking differentials
Disconnecting front sway bar
Factory winch
Package
Power Wagon Level 1 / Level 2
Interior luxury, larger screens, advanced tech
Back to top
2025 Ram 2500 Limited Night Edition Mega Cab 4×4. (HDRams).
Limited
Starting MSRP: $74,245 (2500) / $75,545 (3500)
Limited is the luxury flagship for the Ram Heavy Duty lineup. It’s aimed at buyers who spend long hours
in their truck and want top-tier comfort, technology, and refinement without giving up real HD capability.
Premium leather seating
Large Uconnect touchscreen with available passenger display
Digital instrument cluster
Advanced audio and interior trim
Package
Limited Level 1 Equipment Group
Top-tier towing tech, safety features, and convenience equipment
Back to top
2025 Ram 2500 Limited Longhorn Crew Cab 4×4. (Ram).
Limited Longhorn
Limited Longhorn delivers the same level of luxury as Limited, but with a western-themed design language.
It’s for buyers who want premium materials and a distinctive look that stands apart from the standard
luxury trim.
Premium leather interior with Longhorn design cues
Advanced Uconnect system with large display availability
Digital rearview mirror availability
Package
Longhorn Level 1 Equipment Group
Expanded towing tech, safety systems, and premium convenience features
Back to top
2025 Ram 3500 Heavy Duty Laramie – Black (Ram)
Detailed Towing Tables (Full OEM Charts)
These tables are converted from the official Ram towing specification guides. Use the jump links to get to the exact cab/bed/drivetrain/trim section you need.
Ram 2500 Heavy Duty — Full Towing Charts
RAM 2500 4X2 CREW CAB BIG HORN/LONE STAR 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
Max Trailer Weight Rating
6.4L V8 HEMI UPGRADE HD ENGINE
8-SPD AUTO 8HP75-LCV TRANSMISSION
3.73
10000
3500
6499
3647
2851
5500
6390
22050
15210
4.10
10000
3500
6499
3647
2851
5500
6390
24250
17410
3.73
9900
3400
6499
3647
2851
5500
6390
22050
15210
4.10
9900
3400
6499
3647
2851
5500
6390
24250
17410
6.7L I6 CUMMINS HO TURBO DIESEL ENG
8-SPD TORQUEFLITE HD AUTO TRANS
3.42
9900
2390
7513
4561
2952
5500
6040
27870
19980
3.42
11040
3530
7507
4554
2953
5500
6040
27870
19990
3.42
10000
2490
7507
4554
2953
5500
6040
27870
19990
RAM 2500 4X2 CREW CAB BIG HORN/LONE STAR 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3470
6532
3770
2761
5500
6390
22050
15180
4.10
10000
3470
6532
3770
2761
5500
6390
24250
17380
3.73
9900
3370
6532
3770
2761
5500
6390
22050
15180
4.10
9900
3370
6532
3770
2761
5500
6390
24250
17380
3.42
9900
2270
7631
4664
2966
5500
6040
28010
20000
3.42
11040
3410
7625
4657
2967
5500
6040
28000
20000
3.42
10000
2370
7625
4657
2967
5500
6040
28000
20000
3.73
10000
3140
6859
4081
2777
5500
6390
22050
14850
4.10
10000
3140
6859
4081
2777
5500
6390
24250
17050
3.73
9900
3040
6859
4081
2777
5500
6390
22050
14850
4.10
9900
3040
6859
4081
2777
5500
6390
24250
17050
3.42
11040
3150
7887
4969
2917
6000
6040
26580
18350
3.42
9900
2020
7882
4969
2912
6000
6040
26520
18270
3.42
10000
2110
7887
4969
2917
6000
6040
26580
18320
RAM 2500 4X2 CREW CAB BIG HORN/LONE STAR W/O 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3900
6101
3726
2374
5500
6390
22050
15040
4.10
10000
3900
6101
3726
2374
5500
6390
24250
17240
3.73
9900
3800
6101
3726
2374
5500
6390
22050
15040
4.10
9900
3800
6101
3726
2374
5500
6390
24250
17240
RAM 2500 4X2 CREW CAB BIG HORN/LONE STAR W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3840
6164
0
2363
5500
6390
22050
14910
4.10
10000
3840
6164
3800
2363
5500
6390
24250
17110
3.73
9900
3740
6164
3800
2363
5500
6390
22050
14910
4.10
9900
3740
6164
3800
2363
5500
6390
24250
17110
RAM 2500 4X2 CREW CAB LARAMIE 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3510
6487
3665
2821
5500
6390
22050
15220
4.10
10000
3510
6487
3665
2821
5500
6390
24250
17420
3.73
9900
3410
6487
3665
2821
5500
6390
22050
15220
4.10
9900
3410
6487
3665
2821
5500
6390
24250
17420
3.42
9900
2380
7515
4566
2949
5500
6040
27870
19980
3.42
11040
3530
7509
4559
2950
5500
6040
27870
19990
3.42
10000
2490
7509
4559
2950
5500
6040
27870
19990
RAM 2500 4X2 CREW CAB LARAMIE 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3380
6615
3663
2951
5500
6390
22050
15090
4.10
10000
3380
6615
3663
2951
5500
6390
24250
17290
3.73
9900
3280
6615
3663
2951
5500
6390
22050
15090
4.10
9900
3280
6615
3663
2951
5500
6390
24250
17290
3.42
9900
2260
7643
4564
3079
5500
6040
27870
19850
3.42
11040
3400
7637
4557
3080
5500
6040
27870
19860
3.42
10000
2360
7637
4557
3080
5500
6040
27870
19860
RAM 2500 4X2 CREW CAB LARAMIE 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3370
6627
3777
2849
5500
6390
22050
15080
4.10
10000
3370
6627
3777
2849
5500
6390
24250
17280
3.73
9900
3270
6627
3777
2849
5500
6390
22050
15080
4.10
9900
3270
6627
3777
2849
5500
6390
24250
17280
3.42
9900
2210
7688
4692
2995
5500
6040
28010
19950
3.42
11040
3360
7682
4685
2996
5500
6040
28010
19950
3.42
10000
2320
7682
4685
2996
5500
6040
28010
19950
RAM 2500 4X2 CREW CAB LIMITED 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3190
6807
3800
3006
5500
6390
22050
14900
4.10
10000
3190
6807
3800
3006
5500
6390
24250
17100
3.73
9900
3090
6807
3800
3006
5500
6390
22050
14900
4.10
9900
3090
6807
3800
3006
5500
6390
24250
17100
3.42
9900
2070
7830
4714
3115
5500
6040
27000
18790
3.42
11040
3220
7824
4707
3116
5500
6040
27870
19670
3.42
10000
2180
7824
4707
3116
5500
6040
27870
19670
RAM 2500 4X2 CREW CAB LIMITED 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3060
6942
3798
3144
5500
6390
22050
14770
4.10
10000
3060
6942
3798
3144
5500
6390
24250
16970
3.73
9900
2960
6942
3798
3144
5500
6390
22050
14770
4.10
9900
2960
6942
3798
3144
5500
6390
24250
16970
3.42
9900
1930
7966
4712
3253
5500
6040
25630
17290
3.42
11040
3080
7960
4705
3254
5500
6040
27870
19530
3.42
10000
2040
7960
4705
3254
5500
6040
26800
18460
RAM 2500 4X2 CREW CAB LIMITED 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3040
6964
3942
3021
5500
6390
22050
14750
4.10
10000
3040
6964
3942
3021
5500
6390
24250
16950
3.73
9900
2940
6964
3942
3021
5500
6390
22050
14750
4.10
9900
2940
6964
3942
3021
5500
6390
24250
16950
3.42
9900
1970
7933
4798
3135
5500
6040
26000
17690
3.42
11040
3110
7927
4791
3136
5500
6040
28010
19710
3.42
10000
2070
7927
4791
3136
5500
6040
27170
18870
RAM 2500 4X2 CREW CAB TRADESMAN 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3610
6394
3610
2783
5500
6000
22050
15320
4.10
10000
3610
6394
3610
2783
5500
6000
24250
17520
3.73
9900
3500
6398
3609
2788
5500
6000
22050
15310
4.10
9900
3500
6398
3609
2788
5500
6000
24250
17510
3.42
9900
2460
7435
4540
2894
5500
6040
27810
20000
3.42
11040
3600
7435
4543
2892
5500
6040
27810
20000
3.42
10000
2560
7435
4543
2892
5500
6040
27810
20000
RAM 2500 4X2 CREW CAB TRADESMAN 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3470
6530
3752
2777
5500
6390
22050
15180
4.10
10000
3470
6530
3752
2777
5500
6390
24250
17380
3.73
9900
3360
6537
3756
2781
5500
6390
22050
15170
4.10
9900
3360
6537
3756
2781
5500
6390
24250
17370
3.42
9900
2350
7553
4681
2872
5500
6040
27930
20000
3.42
11040
3500
7539
4668
2870
5500
6000
27910
20000
3.42
10000
2460
7539
4668
2870
5500
6000
27910
20000
RAM 2500 4X2 CREW CAB TRADESMAN W/O 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3940
6055
3729
2325
5500
6390
22050
15090
4.10
10000
3940
6055
3729
2325
5500
6390
24250
17290
3.73
9900
3840
6055
3729
2325
5500
6390
22050
15090
4.10
9900
3840
6055
3729
2325
5500
6390
24250
17290
RAM 2500 4X2 CREW CAB TRADESMAN W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3950
6049
3798
2250
5500
6390
22050
15020
4.10
10000
3950
6049
3798
2250
5500
6390
24250
17220
3.73
9900
3850
6053
3799
2253
5500
6390
22050
15020
4.10
9900
3850
6053
3799
2253
5500
6390
24250
17220
RAM 2500 4X2 REG CAB BIG HORN/LONE STAR 8’0” BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3860
6135
3521
2614
5500
6500
22050
15570
4.10
10000
3860
6135
3521
2614
5500
6500
24250
17770
3.73
9900
3760
6135
3521
2614
5500
6500
22050
15570
4.10
9900
3760
6135
3521
2614
5500
6500
24250
17770
RAM 2500 4X2 REG CAB BIG HORN/LONE STAR W/O BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
4370
5629
3489
2140
5500
6500
22050
15420
4.10
10000
4370
5629
3489
2140
5500
6500
24250
17620
3.73
9900
4270
5629
3489
2140
5500
6500
22050
15420
4.10
9900
4270
5629
3489
2140
5500
6500
24250
17620
RAM 2500 4X2 REG CAB TRADESMAN 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3930
6066
3477
2588
5500
6500
22050
15640
4.10
10000
3930
6066
3477
2588
5500
6500
24250
17840
3.73
9900
3830
6066
3477
2588
5500
6500
22050
15640
4.10
9900
3830
6066
3477
2588
5500
6500
24250
17840
RAM 2500 4X2 REG CAB TRADESMAN W/O BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
4420
5583
3532
2051
5500
6500
22050
15470
4.10
10000
4420
5583
3532
2051
5500
6500
24250
17670
3.73
9900
4310
5586
3530
2055
5500
6500
22050
15470
4.10
9900
4310
5586
3530
2055
5500
6500
24250
17670
RAM 2500 4X4 CREW CAB BIG HORN/LONE STAR 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3260
6742
3943
2799
5500
6390
22050
14970
4.10
10000
3260
6742
3943
2799
5500
6390
24250
17170
3.73
9900
3160
6741
3950
2791
5500
6390
22050
14970
4.10
9900
3160
6741
3950
2791
5500
6390
24250
17170
3.42
11040
3270
7769
4854
2914
6000
6040
28110
19970
3.42
9900
2130
7771
4863
2908
6000
6040
27590
19440
3.42
10000
2230
7769
4854
2914
6000
6040
28110
19970
RAM 2500 4X4 CREW CAB BIG HORN/LONE STAR W/O 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3580
6418
4045
2373
5500
6390
22050
14720
4.10
10000
3580
6418
4045
2373
5500
6390
24250
16920
3.73
9900
3480
6420
4046
2374
5500
6390
22050
14720
4.10
9900
3480
6420
4046
2374
5500
6390
24250
16920
RAM 2500 4X4 CREW CAB BIG HORN/LONE STAR W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3480
6516
4119
2396
5500
6390
22050
14550
4.10
10000
3480
6516
4119
2396
5500
6390
24250
16720
3.73
9900
3380
6516
4119
2396
5500
6390
22050
14550
4.10
9900
3380
6516
4119
2396
5500
6390
24250
16720
RAM 2500 4X4 CREW CAB LARAMIE 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3120
6877
4001
2876
5500
6390
22050
14830
4.10
10000
3120
6877
4001
2876
5500
6390
24250
17030
3.73
9900
3010
6885
4004
2880
5500
6390
22050
14820
4.10
9900
3010
6885
4004
2880
5500
6390
24250
17020
3.42
11040
3170
7871
4911
2959
6000
6040
28110
19860
3.42
9900
2020
7883
4923
2960
6000
6040
26470
18210
3.42
10000
2130
7871
4911
2959
6000
6040
27700
19450
RAM 2500 4X4 CREW CAB LARAMIE 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3040
6957
3950
3007
5500
6390
22050
14750
4.10
10000
3040
6957
3950
3007
5500
6390
24250
16950
3.73
9900
2970
6927
3940
2986
5500
6390
22050
14780
4.10
9900
2970
6927
3940
2986
5500
6390
24250
16980
3.42
11040
3030
8009
4880
3128
6000
6040
28110
19730
3.42
9900
1880
8015
4888
3127
6000
6040
25130
16740
3.42
10000
1990
8009
4880
3128
6000
6040
26300
17920
RAM 2500 4X4 CREW CAB LARAMIE 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3010
6989
4091
2898
5500
6390
22050
14720
4.10
10000
3010
6989
4091
2898
5500
6390
24250
16920
3.73
9900
2910
6989
4090
2898
5500
6390
22050
14720
4.10
9900
2910
6989
4090
2898
5500
6390
24250
16920
3.42
11040
3010
8034
5010
3023
6000
6040
26580
18170
3.42
9900
1870
8034
5013
3021
6000
6040
24980
16570
3.42
10000
1970
8034
5010
3023
6000
6040
26090
17680
RAM 2500 4X4 CREW CAB LIMITED 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
2920
7080
4079
3001
5500
6390
22050
14630
4.10
10000
2920
7080
4079
3001
5500
6390
24250
16830
3.73
9900
2820
7080
4079
3001
5500
6390
22050
14630
4.10
9900
2820
7080
4079
3001
5500
6390
24250
16790
3.42
11040
3000
8038
4994
3043
6000
6040
28110
19700
3.42
9900
1840
8057
4959
3097
6000
6040
24710
16270
3.42
10000
1960
8038
4994
3043
6000
6040
26010
17590
RAM 2500 4X4 CREW CAB LIMITED 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
2780
7219
4078
3140
5500
6390
22050
14490
4.10
10000
2780
7219
4078
3140
5500
6390
24250
16660
3.73
9900
2680
7219
4078
3140
5500
6390
22050
14490
4.10
9900
2680
7219
4078
3140
5500
6390
24250
16660
3.42
11040
2870
8169
4982
3186
6000
6040
28110
19570
3.42
9900
1710
8185
4974
3210
6000
6040
23420
14860
3.42
10000
1830
8169
4982
3186
6000
6040
24690
16140
RAM 2500 4X4 CREW CAB LIMITED 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
2730
7272
4222
3050
5500
6390
22050
14440
4.10
10000
2730
7272
4222
3050
5500
6390
24250
16600
3.73
9900
2630
7272
4222
3050
5500
6390
22050
14440
4.10
9900
2630
7272
4222
3050
5500
6390
24250
16600
3.42
11040
2760
8276
5086
3190
6000
6040
26580
17930
3.42
9900
1620
8282
5093
3189
6000
6040
22470
13810
3.42
10000
1720
8276
5086
3190
6000
6040
23640
14990
RAM 2500 4X4 CREW CAB POWER WAGON 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
4.10
8565
1690
6875
3967
2907
4750
4470
17800
10550
4.10
8565
1530
7032
4172
2860
4750
6200
18000
10590
RAM 2500 4X4 CREW CAB POWER WAGON 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
4.10
8565
1560
7007
3955
3052
4750
4470
17800
10420
4.10
8565
1400
7165
4159
3005
4750
6200
18000
10460
RAM 2500 4X4 CREW CAB REBEL 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
2990
7008
4049
2959
5500
6170
22050
14700
4.10
10000
2990
7008
4049
2959
5500
6170
24250
16900
3.73
9900
2890
7011
4052
2958
5500
6170
22050
14700
4.10
9900
2890
7011
4052
2958
5500
6170
24250
16900
3.42
11040
3070
7972
4917
3055
6000
6040
28110
19760
3.42
9900
1920
7979
4925
3054
6000
6040
25490
17140
3.42
10000
2030
7972
4917
3055
6000
6040
26670
18320
RAM 2500 4X4 CREW CAB REBEL 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
2960
7042
3955
3086
5500
6170
22050
14670
4.10
10000
2960
7042
3955
3086
5500
6170
24250
16870
3.73
9900
2860
7044
3958
3086
5500
6170
22050
14670
4.10
9900
2860
7044
3958
3086
5500
6170
24250
16830
3.42
11040
2950
8086
4934
3151
6000
6040
28110
19650
3.42
9900
1810
8093
4942
3150
6000
6040
24340
15870
3.42
10000
1910
8086
4934
3151
6000
6040
25520
17060
RAM 2500 4X4 CREW CAB TRADESMAN 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3320
6680
3887
2792
5500
6000
22050
15030
4.10
10000
3320
6680
3887
2792
5500
6000
24250
17230
3.73
9900
3210
6689
3897
2791
5500
6000
22050
15020
4.10
9900
3210
6689
3897
2791
5500
6000
24250
17220
3.42
11040
3300
7742
4807
2935
5750
6000
28110
19990
3.42
9900
2170
7728
4800
2927
5750
6000
28030
19930
3.42
10000
2260
7742
4807
2935
5750
6000
28110
19990
RAM 2500 4X4 CREW CAB TRADESMAN 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3110
6886
4059
2827
5500
6000
22050
14820
4.10
10000
3110
6886
4059
2827
5500
6000
24250
17020
3.73
9900
3020
6875
4055
2820
5500
6000
22050
14830
4.10
9900
3020
6875
4055
2820
5500
6000
24250
17030
3.42
11040
3160
7877
4959
2918
5750
6000
26580
18360
3.42
9900
2010
7888
4969
2919
5750
6000
26460
18190
3.42
10000
2120
7877
4959
2918
6000
6040
26580
18330
RAM 2500 4X4 CREW CAB TRADESMAN 8’0″ BOX PAYLOAD UPG
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4010
7025
4105
2920
5500
7000
22050
14680
4.10
11040
4010
7025
4105
2920
5500
7000
24250
16880
RAM 2500 4X4 CREW CAB TRADESMAN PW 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
4.10
8565
1570
6992
4149
2843
4750
6200
18000
10630
RAM 2500 4X4 CREW CAB TRADESMAN W/O 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3700
6295
3976
2318
5500
6390
22050
14850
4.10
10000
3700
6295
3976
2318
5500
6390
24250
17050
3.73
9900
3600
6295
3976
2318
5500
6390
22050
14850
4.10
9900
3600
6295
3976
2318
5500
6390
24250
17050
RAM 2500 4X4 CREW CAB TRADESMAN W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3570
6434
4126
2308
5500
6390
22050
14640
4.10
10000
3570
6434
4126
2308
5500
6390
24250
16840
3.73
9900
3450
6451
4095
2356
5500
6390
22050
14620
4.10
9900
3450
6451
4095
2356
5500
6390
24250
16780
RAM 2500 4X4 MEGA CAB LARAMIE 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
11040
2900
8137
5041
3096
6000
6040
24290
15810
3.42
9900
1790
8105
5009
3096
6000
6040
24210
15730
3.42
10000
1860
8137
5041
3096
6000
6040
24290
15780
RAM 2500 4X4 MEGA CAB LARAMIE 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
11040
2830
8207
4967
3240
6000
6040
24290
15740
3.42
9900
1680
8219
4977
3241
6000
6040
23070
14480
3.42
10000
1790
8207
4967
3240
6000
6040
24290
15710
RAM 2500 4X4 MEGA CAB LIMITED 6’4″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
11040
2810
8228
5106
3122
6000
6040
24290
15720
3.42
9900
1680
8217
5072
3144
6000
6040
23090
14500
3.42
10000
1770
8228
5106
3122
6000
6040
24080
15480
RAM 2500 4X4 MEGA CAB LIMITED 6’4″ BOX W/ RAMBOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
11040
2540
8499
5120
3378
6000
6040
24290
15420
3.42
9900
1430
8473
5080
3392
6000
6040
20510
11660
3.42
10000
1500
8499
5120
3378
6000
6040
21360
12480
RAM 2500 4X4 REG CAB BIG HORN/LONE STAR 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3610
6390
3795
2594
5500
6390
22050
15320
4.10
10000
3610
6390
3795
2594
5500
6390
24250
17520
3.73
9900
3500
6402
3796
2605
5500
6390
22050
15310
4.10
9900
3500
6402
3796
2605
5500
6390
24250
17510
3.42
11040
3590
7449
4686
2763
6000
6040
27790
20000
3.42
9900
2440
7459
4690
2768
6000
6040
27820
19990
3.42
10000
2550
7449
4686
2763
6000
6040
27820
20000
RAM 2500 4X4 REG CAB BIG HORN/LONE STAR W/O BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3990
6012
3801
2210
5500
6390
22050
15040
4.10
10000
3990
6012
3801
2210
5500
6390
24250
17240
3.73
9900
3890
6012
3801
2210
5500
6390
22050
15040
4.10
9900
3890
6012
3801
2210
5500
6390
24250
17240
RAM 2500 4X4 REG CAB TRADESMAN 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
3630
6374
3748
2626
5500
6390
22050
15340
4.10
10000
3630
6374
3748
2626
5500
6390
24250
17540
3.73
9900
3510
6385
3755
2630
5500
6390
22050
15320
4.10
9900
3510
6385
3755
2630
5500
6390
24250
17520
3.42
11040
3590
7446
4693
2753
5750
6000
27790
20000
3.42
9900
2450
7449
4703
2745
5750
6000
27820
20000
3.42
10000
2550
7446
4693
2753
5750
6000
27820
20000
RAM 2500 4X4 REG CAB TRADESMAN 8’0″ BOX PAYLOAD UPG
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4580
6463
3764
2699
5500
7000
22050
15250
4.10
11040
4580
6463
3764
2699
5500
7000
24250
17450
RAM 2500 4X4 REG CAB TRADESMAN W/O BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
10000
4070
5926
3827
2098
5500
6390
22050
15130
4.10
10000
4070
5926
3827
2098
5500
6390
24250
17330
3.73
9900
3980
5923
3753
2170
5500
6390
22050
15130
4.10
9900
3980
5923
3753
2170
5500
6390
24250
17330
Ram 3500 Heavy Duty — Full Towing Charts
RAM 3500 4X2 CREW CAB BIG HORN/LONE STAR 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4570
6467
3641
2826
5500
7000
22000
15190
4.10
11040
4570
6467
3641
2826
5500
7000
24240
17430
3.42
11500
4060
7442
4511
2930
5500
7000
31850
24070
RAM 3500 4X2 CREW CAB BIG HORN/LONE STAR 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
7070
6932
3774
3157
5500
9750
22600
15330
4.10
14000
7070
6932
3774
3157
5500
9750
25000
17730
3.42
14000
5910
8089
4697
3392
5500
9750
43040
34610
3.42
13500
5350
8153
4729
3424
5500
9750
41870
33370
RAM 3500 4X2 CREW CAB BIG HORN/LONE STAR 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
4600
6546
3738
2808
5500
7000
22000
15110
4.10
11150
4600
6546
3738
2808
5500
7000
24240
17350
3.42
12000
4390
7612
4666
2945
5500
7000
33530
25580
RAM 3500 4X2 CREW CAB BIG HORN/LONE STAR W/O 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5020
6024
3693
2331
5500
7000
22000
15070
4.10
11040
5020
6024
3693
2331
5500
7000
24240
17310
RAM 3500 4X2 CREW CAB BIG HORN/LONE STAR W/O 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
5110
6036
3769
2267
5500
7000
22000
14980
4.10
11150
5110
6036
3769
2267
5500
7000
24240
17220
RAM 3500 4X2 CREW CAB LARAMIE 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4450
6588
3718
2869
5500
7000
22000
15070
4.10
11040
4450
6588
3718
2869
5500
7000
24240
17310
3.42
11500
3940
7557
4582
2974
5500
7000
31850
23950
RAM 3500 4X2 CREW CAB LARAMIE 6’4″ BOX W/ RAMBOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4340
6695
3710
2985
5500
7000
22000
14960
4.10
11040
4340
6695
3710
2985
5500
7000
24240
17200
3.42
11500
3840
7663
4573
3089
5500
7000
31310
23310
RAM 3500 4X2 CREW CAB LARAMIE 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6930
7074
3836
3237
5500
9750
22600
15190
4.10
14000
6930
7074
3836
3237
5500
9750
25000
17590
3.42
14000
5860
8136
4724
3412
5500
9750
43040
34560
3.42
13500
5360
8138
4725
3413
5500
9750
41960
33480
RAM 3500 4X2 CREW CAB LARAMIE 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
4530
6620
3740
2880
5500
7000
22000
15040
4.10
11150
4530
6620
3740
2880
5500
7000
24240
17280
3.42
12000
4310
7690
4712
2977
5500
7000
33530
25500
RAM 3500 4X2 CREW CAB LIMITED/LONG HORN 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4250
6790
3805
2985
5500
7000
22000
14870
4.10
11040
4250
6790
3805
2985
5500
7000
24240
17110
3.42
11500
3670
7832
4708
3124
5500
7000
31210
23000
RAM 3500 4X2 CREW CAB LIMITED/LONG HORN 6’4″ BOX W/ RAMBOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4100
6935
3803
3132
5500
7000
22000
14720
4.10
11040
4100
6935
3803
3132
5500
7000
24240
16960
3.42
11500
3520
7977
4706
3271
5500
7000
31350
23000
RAM 3500 4X2 CREW CAB LIMITED/LONG HORN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6680
7324
4035
3289
5500
9750
22600
14940
4.10
14000
6680
7324
4035
3289
5500
9750
25000
17340
3.42
14000
5560
8440
4879
3560
5500
9750
43040
34260
3.42
13500
5060
8442
4880
3561
5500
9750
40240
31450
RAM 3500 4X2 CREW CAB LIMITED/LONG HORN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
4220
6928
3974
2954
5500
7000
22000
14730
4.10
11150
4220
6928
3974
2954
5500
7000
24240
16970
3.42
12000
4050
7951
4893
3057
5500
7000
33020
24720
RAM 3500 4X2 CREW CAB TRADESMAN 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4580
6455
3636
2818
5500
7000
22000
15200
4.10
11040
4580
6455
3636
2818
5500
7000
24240
17440
3.42
11500
4040
7459
4501
2957
5500
7000
31850
24050
RAM 3500 4X2 CREW CAB TRADESMAN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6990
7013
3822
3190
5500
9750
22600
15250
4.10
14000
6990
7013
3822
3190
5500
9750
25000
17650
3.42
14000
5890
8110
4724
3385
5500
9750
43040
34590
3.42
13500
5390
8111
4725
3386
5500
9750
42110
33650
RAM 3500 4X2 CREW CAB TRADESMAN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
4520
6628
3760
2867
5500
7000
22000
15030
4.10
11150
4520
6628
3760
2867
5500
7000
24240
17270
3.42
12000
4400
7603
4647
2956
5500
7000
33530
25590
RAM 3500 4X2 CREW CAB TRADESMAN W/O 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5030
6014
3690
2324
5500
7000
22000
15080
4.10
11040
5030
6014
3690
2324
5500
7000
24240
17320
RAM 3500 4X2 CREW CAB TRADESMAN W/O 8’0” BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11150
5050
6099
3819
2280
5500
7000
22000
14920
4.10
11150
5050
6099
3819
2280
5500
7000
24240
17160
RAM 3500 4X2 REG CAB BIG HORN/LONE STAR 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
7540
6456
3498
2957
5500
9750
22600
15800
4.10
14000
7540
3498
2957
5500
9750
25000
18200
3.73
4.10
14000
7250
6751
3780
2971
5500
9750
25000
17910
3.42
14000
6060
7937
4704
3232
6000
9750
45000
36720
3.42
13500
5540
7961
4704
3256
6000
9750
42960
34660
RAM 3500 4X2 REG CAB BIG HORN/LONE STAR 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5000
6035
3449
2586
5500
7000
22000
15620
4.10
11040
5000
6035
3449
2586
5500
7000
24240
17860
RAM 3500 4X2 REG CAB BIG HORN/LONE STAR W/O 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5520
5524
3487
2037
5500
7000
22000
15480
4.10
11040
5520
5524
3487
2037
5500
7000
24240
17720
RAM 3500 4X2 REG CAB TRADESMAN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
7590
6408
3449
2958
5500
9750
22600
15850
4.10
14000
7590
6408
3449
2958
5500
9750
25000
18250
RAM 3500 4X2 REG CAB TRADESMAN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4970
6072
3431
2640
5500
7000
22000
15590
4.10
11040
4970
6072
3431
2640
5500
7000
24240
17830
RAM 3500 4X2 REG CAB TRADESMAN W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5490
5551
3470
2081
5500
7000
22000
15450
4.10
11040
5490
5551
3470
2081
5500
7000
24240
17690
RAM 3500 4X4 CREW CAB BIG HORN/LONE STAR 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4290
6752
3922
2829
5500
7000
22000
14910
4.10
11040
4290
6752
3922
2829
5500
7000
24240
17150
3.42
11800
4050
7746
4796
2949
6000
7000
31820
23730
RAM 3500 4X4 CREW CAB BIG HORN/LONE STAR 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6690
7313
4065
3248
5500
9750
22600
14950
4.10
14000
6690
7313
4065
3248
5500
9750
25000
17350
3.42
14000
5560
8435
5026
3408
6000
9750
42800
34020
3.42
13500
4950
8545
5086
3459
6000
9750
39650
30760
RAM 3500 4X4 CREW CAB BIG HORN/LONE STAR 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
4520
6916
4035
2880
5500
7000
22000
14740
4.10
11440
4520
6916
4035
2880
5500
7000
24240
16980
3.42
12300
4370
7933
4944
2989
6000
7000
33610
25340
RAM 3500 4X4 CREW CAB BIG HORN/LONE STAR W/O 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4720
6319
3961
2358
5500
7000
22000
14770
4.10
11040
4720
6319
3961
2358
5500
7000
24240
17010
RAM 3500 4X4 CREW CAB BIG HORN/LONE STAR W/O 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
5000
6443
4097
2346
5500
7000
22000
14580
4.10
11440
5000
6443
4097
2346
5500
7000
24240
16820
RAM 3500 4X4 CREW CAB LARAMIE 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4160
6884
3948
2936
5500
7000
22000
14780
4.10
11040
4160
6884
3948
2936
5500
7000
24240
17020
3.42
11800
3810
7991
4903
3088
6000
7000
31450
23120
RAM 3500 4X4 CREW CAB LARAMIE 6’4″ BOX W/ RAMBOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4050
6992
3940
3051
5500
7000
22000
14670
4.10
11040
4050
6992
3940
3051
5500
7000
24240
16910
3.42
11800
3740
8060
4843
3217
6000
7000
31440
23000
RAM 3500 4X4 CREW CAB LARAMIE 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6610
7388
4134
3253
5500
9750
22600
14870
4.10
14000
6610
7388
4134
3253
5500
9750
25000
17270
3.42
14000
5460
8544
5083
3461
6000
9750
42800
33920
3.42
13500
4980
8521
5080
3440
6000
9750
39790
30930
RAM 3500 4X4 CREW CAB LARAMIE 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
4400
7039
4121
2917
5500
7000
22000
14620
4.10
11440
4400
7039
4121
2917
5500
7000
24240
16860
3.42
12300
4180
8116
5065
3051
6000
7000
33610
25150
RAM 3500 4X4 CREW CAB LIMITED/LONG HORN 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
3870
7174
4114
3060
5500
7000
22000
14490
4.10
11040
3870
7174
4114
3060
5500
7000
24240
16730
3.42
11800
3650
8152
4974
3178
6000
7000
31530
23000
RAM 3500 4X4 CREW CAB LIMITED/LONG HORN 6’4″ BOX W/ RAMBOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
3720
7319
4112
3207
5500
7000
22000
14340
4.10
11040
3720
7319
4112
3207
5500
7000
24240
16580
3.42
11800
3500
8304
4977
3326
6000
7000
31680
23000
RAM 3500 4X4 CREW CAB LIMITED/LONG HORN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6350
7646
4261
3385
5500
9750
22600
14610
4.10
14000
6350
7646
4261
3385
5500
9750
25000
17010
3.42
14000
5300
8698
5167
3531
6000
9750
42120
33080
3.42
13500
4780
8721
5176
3545
6000
9750
38650
29590
RAM 3500 4X4 CREW CAB LIMITED/LONG HORN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
4130
7314
4248
3066
5500
7000
22000
14350
4.10
11440
4130
7314
4248
3066
5500
7000
24240
16590
3.42
12300
3900
8402
5187
3214
6000
7000
32460
23720
RAM 3500 4X4 CREW CAB TRADESMAN 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4250
6794
3911
2882
5500
7000
22000
14870
4.10
11040
4250
6794
3911
2882
5500
7000
24240
17110
3.42
11800
3970
7827
4819
3008
6000
7000
31820
23650
RAM 3500 4X4 CREW CAB TRADESMAN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
6640
7357
4126
3231
5500
9750
22600
14900
4.10
14000
6640
7357
4126
3231
5500
9750
25000
17300
3.42
14000
5530
8470
5053
3417
6000
9750
42800
33990
3.42
13500
5050
8445
5020
3425
6000
9750
40210
31430
RAM 3500 4X4 CREW CAB TRADESMAN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
4440
7004
4097
2906
5500
7000
22000
14660
4.10
11440
4440
7004
4097
2906
5500
7000
24240
16900
3.42
12300
4310
7991
4997
2993
6000
7000
33610
25280
RAM 3500 4X4 CREW CAB TRADESMAN W/O 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4730
6305
3944
2360
5500
7000
22000
14790
4.10
11040
4730
6305
3944
2360
5500
7000
24240
17030
RAM 3500 4X4 CREW CAB TRADESMAN W/O 8’0” BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11440
4990
6453
4114
2339
5500
7000
22000
14570
4.10
11440
4990
6453
4114
2339
5500
7000
24240
16810
RAM 3500 4X4 MEGA CAB LARAMIE 6’4″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
14000
5380
8620
5053
3566
6000
9750
41950
32990
3.42
13500
4910
8587
5009
3577
6000
9750
39410
30480
RAM 3500 4X4 MEGA CAB LARAMIE 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
12300
4100
8201
5029
3171
6000
7000
32720
24180
RAM 3500 4X4 MEGA CAB LIMITED/LONG HORN 6’4″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
14000
5210
8785
5148
3636
6000
9750
41620
32490
3.42
13500
4710
8792
5140
3652
6000
9750
38250
29110
RAM 3500 4X4 MEGA CAB LIMITED/LONG HORN 6’4″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
12300
3840
8460
5158
3301
6000
7000
32130
23330
RAM 3500 4X4 MEGA CAB LIMITED/LONG HORN 6’4″ BOX W/ RAMBOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.42
12300
3710
8587
5147
3440
6000
7000
31960
23000
RAM 3500 4X4 REG CAB BIG HORN/LONE STAR 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4670
6374
3720
2654
5500
7000
22000
15290
4.10
11040
4670
6374
3720
2654
5500
7000
24230
17520
3.42
11830
4410
7419
4642
2776
6000
7000
34000
26240
RAM 3500 4X4 REG CAB BIG HORN/LONE STAR W/O 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5160
5877
3771
2106
5500
7000
22000
15130
4.10
11040
5160
5877
3771
2106
5500
7000
24230
17360
RAM 3500 4X4 REG CAB TRADESMAN 8’0″ BOX DRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
14000
7200
6796
3780
3015
5500
9750
22600
15460
4.10
14000
7200
6796
3780
3015
5500
9750
25000
17860
3.42
14000
6050
7947
4718
3228
6000
9750
45000
36710
3.42
13500
5580
7917
4727
3190
6000
9750
43200
34950
RAM 3500 4X4 REG CAB TRADESMAN 8’0″ BOX SRW
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
4580
6462
3762
2699
5500
7000
22000
15200
4.10
11040
4580
6462
3762
2699
5500
7000
24230
17430
3.42
11830
4350
7478
4655
2823
6000
7000
34000
26180
RAM 3500 4X4 REG CAB TRADESMAN W/O 8’0″ BOX
Engine
Trans.
Axle Ratio
GVWR
Payload
Base Weight Total
Base Weight Front
Base Weight Rear
GAWR Front
GAWR Rear
GCWR
3.73
11040
5140
5902
3784
2117
5500
7000
22000
15100
4.10
11040
5140
5902
3784
2117
5500
7000
24230
17330
Which Trim Should You Buy?
Buyer use-case
Best fit
Why
Best value work truck
Tradesman or Black Express
Gets you into HD capability without paying for luxury content you won’t use. Build around towing groups and the right cab/bed.
Gateway off-road HD
Warlock
Off-road hardware focus at a lower price point than Rebel; good for job sites, winter, and rough access roads.
Best daily driver balance
Flexible equipment groups let you add comfort/tech without jumping into full luxury pricing.
Best off-road capability (specialty)
Power Wagon
Purpose-built off-road focus; don’t choose it for maximum towing or diesel availability.
Best “nice interior, still a truck.”
Laramie
Often, the sweet spot for comfort and tech availability without the full luxury trim premiums.
Best luxury
Limited Longhorn or Limited
Top trims concentrate premium tech and comfort options; Limited Level 1 listing includes tow/safety tech content in the equipment group shown.
Best tow rig
3500 Cummins HO DRW
The towing charts show the highest GCWR and max trailer ratings in DRW diesel configurations (example: 45,000 GCWR / 36,720 max trailer).
Quick takeaway: If you’re stuck between 2500 and 3500, decide based on your real weights. If you’re consistently near the limits, it’s usually smarter (and calmer) to step into the 3500.
Final Thoughts
The 2026 Ram Heavy Duty lineup doesn’t try to reinvent itself. Instead, it builds on the major 2025 overhaul and sharpens the entry point with the new 2500 Black Express and 2500 Warlock. The bigger story for real buyers is that GVWR and payload ratings can change due to certification updates, making it even more important to shop the official towing charts rather than assumptions or old numbers.
The best way to buy one of these trucks is boring but effective:
Pick your trailer and payload reality first, choose 2500 vs 3500, pick gas vs diesel, then choose the trim that fits how you’ll live with the truck every day. A correctly spec’d “lower” trim will beat the wrong high trim every time.
Back to top
Ram Heavy Duty Gallery:
This slideshow requires JavaScript.
