Thats not what the shutters are there for….Will the active shutters not negate the need for the cold front?
I have never had to pull the front cover when towing the only time the truck has gotten above the normals temps for me is with the plow on as it redirects the windYes you need to open another one, and yes you should pull it to tow.
I always pull it to tow, even when it’s well below freezing.
Redirecting airflow for aerodynamics mainly but they also dont block the whole rad like the winter front doesWhat are the shutters there for?
I have all my flaps open and still running over 200Yes you need to open another one, and yes you should pull it to tow.
What’s the ambient temp?I have all my flaps open and still running over 200
33 degrees. Not towing 65mphWhat’s the ambient temp?
You’re not towing, correct?
28° here this morning and I’m running 188-190° at 50-55.
In the owners manual it say acceptable ect range is 180-206 and short peaks of 225 is ok under towing conditions
