Will a Battery Tender Charge both Batteries?
According to Battery Tender you should connect the positive clip to one battery and the ground clip to the other battery. That way, depending on what BT you have, the BT sees two batteries and can give you a readout for each battery. If you put both clips on one battery the BT sees both as one battery.
Also, to work properly you need a BT of sufficient amperage. Too low amperage rating and the BT cannot keep batteries at full charge. Been there, done that!
However, in the latter situation it really doesn't matter in the long run because once the light is solid green that indicates both batteries are fully charged and the tender is trickling both correct? My Battery Tender has one red and one greed LED, won't read out for two separate batteries.
My low powered maintainers also showed a solid light indicating batteries were fully charged but were not maintaining and eventually the batteries went dead. My son had the same experience with his low powered maintainers.
As for reading separate batteries, I said it depends on what BT you have.
Hmm, solid green light but the batteries died anyway? That's disheartening. I have a BT Plus 1.25A. What's everyone else using to keep the two batteries properly tended?
I'm using a NoCo Genius 10 (10amp) on my two battery Ram HO Cummins and a Noco Genius 7200 (7.2amps) on my one battery Ram Ecodiesel. Got rid of all my less than 5amp maintainers.
I have a Minn Kota, 20 amp, 2-Bank On-Board Battery Charger - # MK-220PC on order to use on my Cummins. Will probably hardwire and mount it permanently.
Are you going to hook up both banks on the MK-220PC, one per battery? Since the batteries are connected won’t that mess up with the separate banks from the charger? I’m asking because I wanted to add an on-board charger as well, but thought the dual bank chargers wouldn’t work with the dual battery setup.
I was considering the Noco, but looks like your moving away from it? Does it not work well?
I run the 1.25 deltran and my truck didn’t run for months over the winter and it kept the batteries fully charged.
Yes, one bank per battery. You ask a good question. I assumed that each battery having a ground and positive from the charger it could see it as a separate battery. I assumed this because of Battery Tender's statement when using a one-bank charger (with the sophistication) to put the ground on one battery and the positive on the other. Your question now poses some doubt to my assumption. I'm going to call a couple of companies that have multi-bank chargers and pose the question.
Thanks for the question, makes me wonder :confused:
Edit: The NoCo works great but for its size it's hard to find a place to mount in the truck. Plus Noco advised against putting where heat, vibration and water can reach it. The Minn Kota is made for the marine environment so it should do well on the truck. I've had similar Mini Kotos in my boat for the last 15 years and they are still like new, just dirty.
Just curious because I was seriously considering the noco (probably the 10 amp), is it not meeting your expectations?
That's a great charger. BT did not recommend it for my amp hours rated battery, and especially not for a two battery system.
The 2-bank charger will work fine. You can even hook up both leads to the same battery if you want and it will put out 20-amps. It is covered in the manual available online.
It's a great charger, very satisfied. Just want to go to a 2-bank system with smaller units.
Thanks Carl,
You saved me a couple of phone calls.
I just ordered the Deltran 5amp weather resistant.
Good choice. That's the one that BT suggested for my single battery. It meets all the requirements
If the batteries are good, most late model 1-3A chargers will keep them up. I use a 1.5A charger in conjunction with the block heater when it's really frosty out. Not to charge the batteries per se, just to keep them warm.
I had an under 3 A charger on brand new AGM batteries and it failed to maintain them. In fact, over time drew them down below starting level.
I would suspect a defective "new" battery or charger. I've got dual AGM boat batteries on the roll'n dog house. A 1.5A overnight charge will bring them both up to speed after they've been sitting idle for a month.
No, it wasn't the charger. As I said, my son had the same experience. We both sent the chargers back to the manufacturer for testing. They said the chargers were fine, get a higher amp charger. Batteries were not defective
