Vibration when turning at slow speeds
2022 Ram 2500 diesel Laramie – w/out assisted steering.
Symptoms: Grinding noise & vibration you can hear and also feel in the steering wheel and the floorboard when in tight turns at slow speeds only. The vibration cannot be felt with the truck in park and turning the wheels in either direction. The vibration cannot be felt when the truck is up on a lift. Braking is no change; it’s not the brakes nor low steering fluid.
I bought the truck used with only 18k miles from a young man in Texas who had added 2” lift plus steering stabilizers. The lift caused the front differential to fail which Ram replaced under warranty, and at the same time I had the Ram service center remove everything aftermarket and return the truck to Mopar stock parts. I also replaced the all terrain tires with new Michelin highway tires which also quieted the truck down significantly. But this vibration in the steering at low speeds in tight turns remains and is getting worse, now at 65k miles.
The front end was inspected with the truck on a lift which resulted in replacing both front hubs. But the steering vibration is still there.
I’ve had the truck inspected on a lift at a different shop, and they found nothing. All zirks were topped off. When on the rack, the vibration can no longer be felt in the steering wheel; the vibration is only when the truck is moving at less than 15mph and in a tight turn. The vibration will continue for ~10 seconds as you straighten out.
Ram Service advisor recommends replacing the steering box for $3500, although his reasoning is only that he has seen this be a common problem. He did no diagnostics. From what I read, a steering box failure will cause the steering to be sloppy and/or you feel a skipping. This is not what I feel; I feel and a hear a vibration and grinding which is getting worse.
I’m wondering if the joints in the steering column could be failing, but wouldn’t this also be felt when the truck is in park and turning the wheels side to side? Why do I only feel it when driving slowly and turning?
I read in one forum post where the same symptoms were cured by replacing the front axle locker actuator. I’m still trying to understand how this would cause a vibration only when turning and only when under load.
Could this be something in the rear even though it feels to be coming from the front?
Yeah sounds like its stuck in 4WD. That’s how it sounds when you turn on dry surfaces with 4WD engaged.
Was the vibration there prior to the dealer replacing the front differential and taking the lift off? I'm struggling to understand a way a 2" lift (assuming just a leveling kit) can cause a front differential to fail... Was the diff used or new? Did they replace any other parts like the front axle u-joints?
Also, is it just a vibration or does the truck seem to bind and stop if the tight turn is maintained? The truck isn't in 4wd is it?
If I had to throw something at the wall and see if it sticks, the truck is either in 4wd or one of the front axle u-joints is either installed incorrectly or absolutely smoked.
I know what driving in 4wd on pavement sounds and feels like, and that is not this. That's a bucking/jumping. This is a vibration and a growling sound. But thanks for your reply.
Yes, the vibration was there both before and after Ram replaced all of the aftermarket suspension and also replaced the front differential and the front axle under warranty. When I picked the truck up from this work, the vibration in tight turns at slow speeds was still there. I knew it immediately from just pulling out of the parking space at the service center. I told the service advisor who was very upset the truck had been released to me without the remedying my complaint, and had the tech go for a test drive with me so I could be sure he felt the problem. The tech could feel the vibration but didn't know the cause only from a test drive. The service advisor then recommended replacing the steering box for $3000. Everything I read about steering box failure diagnostics does not agree with my truck symptoms, so I have not yet replaced the steering box.
So to answer your reply questions, yes, the front differential replaced by Ram was new. And yes, the axle u-joints were replaced and the front drive shaft was replaced so I assume that would include the drive shaft u-joints.
When driving the truck slowly in a tight turn, the truck does not seem to bind or stop. You feel a very noticeable vibration both in the steering wheel and through the floor both on the driver side and the passenger side. The vibration is very much there and the growling noise is faint but definitely there.
No, the truck is definitely not in 4wd (I wish it was that simple!) I have wondered if an axle locker actuator is possibly stuck. I don't know how to diagnose that.
Is the growl/vibration speed or rpm dependent? Does it happen in drive and reverse? Have you pulled the front driveshaft and tested for the vibration?
I would not authorize the steering box replacement either. If you want my honest opinion I would search out another reputable shops opinion. It really sounds like the dealer you are at doesn’t have techs worth their salt - just throwing parts at things.
Find a good independent on Google, take it there and pay them to diagnose it. Then take it back to the dealer for warranty work.
Stock wheels and tire size?
After reading your reply, I tried it in reverse and the grind is still there even in reverse.
I have pulled the driveshaft and tested for vibration (didn't know one can do that). The drive shaft was recently replaced by Ram and the vibration existed both before and after that replacement, so that being the problem seems improbable.
Thanks for advising to NOT replace the steering box, at least not yet.
It has stock 20" rims, and I replaced the all terrain tires from the previous owner with new Michelin highway tires. That smoothed out the ride quite a bit.
My first attempt at diagnostics was at a reputable off-road specialty shop and they recommended ~$5k of work including replacing the drive shaft with one that has a modified flange which could withstand the offset angle. I wasn't ready at that time, as this was the first diagnostics done, to spend that kind of money. It was then that I took the truck to Ram who recommended taking the truck back to stock which I wanted to do anyway. So I authorized that work which was done, and at the same time, Ram found the front differential was shot as a result to bad angle on the drive shaft, and they replaced the front differential, drive shaft, and front axle under warranty. So taking it to Ram turned out to be the right move. This fixed the most critical problem of the truck literally falling apart when in 4wd. Now I'm trying to find the problem which still remains, the grinding/vibration at low speeds in tight turns. If I can find and fix problem, I'll keep the truck.
I'm thinking to now take it to 2 different off-road specialty shops and 1 different Ram service, pay for diagnostics, and see how they compare.
I will say, I have never heard of a 2” level “destroying the front differential”. That diagnosis alone is somewhat suspect to me, but I suppose nothing is impossible.
Watching this thread closely. I’d be really curious as to what the fix ends up being.
I totally agree in that I've wondered about it being in the transfer case. I need to read more on the symptoms there.
This morning I emailed Red Head Steering boxes and the salesman called me back within the day. He was extremely helpful and after discussing the whole situation at length, he too agrees it's highly doubtful the steering box is failing. Of course anything is possible.
Today I did notice that the sheave on the steering fluid pump has a very slight wobble. I plan to take a video and post it here. I also took the truck to a respected diesel shop in Phoenix and their advisor spent quite a bit of time with me and the truck. He saw the wobble on the sheave, but didn't believe it to be enough to be causing vibrate the whole front end so much that you feel it in the floorboards on both sides of the truck. We also discussed the possibility of an axle locker actuator being stuck, but he's only seen them fail to the open position, not the locked position. He also doesn't believe anything in the rear such as the rear differential going bad would be felt in the steering wheel. He also confirmed that the steering fluid appears to be in good shape and not discolored. I am going to flush and change the steering fluid since it's cheap and should be done anyway. In summary, after this diesel spent a solid half hour discussing it with me and thinking it through, he too has no clue.
I keep coming back to the fact that the vibration is excited only when driving at turning at slow speeds and not turning the when idling. Both hubs were just changed and that didn't stop it.
Good grief... but then we'll see where this goes next. I've been saying to myself, there must be some Chinese made listening device that can be attached to various components, and the signal sent wirelessly to your phone. This must exist, and why haven't any of these shops I've gone to used such a diagnostics device? Yesterday morning I bought a Steelman 2 Chassis Ears on Amazon for $136 and it arrived this morning. This one is not wireless transmission, it connects with a 10' cable, but it worked just fine given I'm using it at very slow speeds.
I can't recommend this enough!!! The clamp (microphone) was moved around to a couple dozen positions including both front wheel areas, the steering box, the front differential, rear differential, and transfer case. There was a distinctly different noise coming from the nut holding the lower ball joint on the drivers side. The same position on the passenger side was quiet. The only reason I can think of to explain why this was not found sooner, given how many mechanics have looked at the entire suspension on this truck, is that the Chassis Ears enabled detecting the failure point long before a visual inspection could detect the failure.
Of course I won't know if this was the entire problem until the ball joint is replaced. There's definitely a crackling noise heard through the headphones when the clamp (microphone) is attached to the nut on the lower ball joint; it's definitely louder only there and no where else we found. Crazy if it's been something this obvious all this time, and yet no mechanic had found it. We'll see.
Hello, @Frustrated 2500 owner!
If you are interested in additional support here, then please send us your VIN via private message. We would love to escalate a customer care case for you!
Hannah
Ram Cares
I found an excellent off-road shop in Phoenix called Desert Rat, and the owner spent easily over an hour going over the truck with me. He found where the drag link had been installed with the bend facing to the rear and was rubbing in a tight left turn. He aligned the truck and corrected this rubbing. That helped, but the growling is still there. The owner drove the truck again and agrees the growling/vibration is still there, but he doesn't have any idea what is causing it.
One conclusion being reached is that the previous owner of the truck, a young man, must have driven it in a wildly extreme manner to have damaged the front differential in the first 18,000 miles. Everyone agrees that the 2" lift should not have done so much damage. And so what else could have been damaged in those first 18,000 miles that is now haunting me? Desert Rat did give me a quote to replace the steering box for $1700 installed, FAR less than the Ram dealership quoted. And I was advised to not use a Red Head steering box either. Desert Rat doesn't believe this is the remaining problem, but agrees there's very little else it could be.
I'm being advised to continue driving the truck until this problem becomes more exaggerated and will be easier to find.
This is going to sound stupid given all you’ve already done, but has anyone checked to make sure a tire isn’t rubbing on something in those turns?
