Vibration when turning at slow speeds
2022 Ram 2500 diesel Laramie – w/out assisted steering.
Symptoms: Grinding noise & vibration you can hear and also feel in the steering wheel and the floorboard when in tight turns at slow speeds only. The vibration cannot be felt with the truck in park and turning the wheels in either direction. The vibration cannot be felt when the truck is up on a lift. Braking is no change; it’s not the brakes nor low steering fluid.
I bought the truck used with only 18k miles from a young man in Texas who had added 2” lift plus steering stabilizers. The lift caused the front differential to fail which Ram replaced under warranty, and at the same time I had the Ram service center remove everything aftermarket and return the truck to Mopar stock parts. I also replaced the all terrain tires with new Michelin highway tires which also quieted the truck down significantly. But this vibration in the steering at low speeds in tight turns remains and is getting worse, now at 65k miles.
The front end was inspected with the truck on a lift which resulted in replacing both front hubs. But the steering vibration is still there.
I’ve had the truck inspected on a lift at a different shop, and they found nothing. All zirks were topped off. When on the rack, the vibration can no longer be felt in the steering wheel; the vibration is only when the truck is moving at less than 15mph and in a tight turn. The vibration will continue for ~10 seconds as you straighten out.
Ram Service advisor recommends replacing the steering box for $3500, although his reasoning is only that he has seen this be a common problem. He did no diagnostics. From what I read, a steering box failure will cause the steering to be sloppy and/or you feel a skipping. This is not what I feel; I feel and a hear a vibration and grinding which is getting worse.
I’m wondering if the joints in the steering column could be failing, but wouldn’t this also be felt when the truck is in park and turning the wheels side to side? Why do I only feel it when driving slowly and turning?
I read in one forum post where the same symptoms were cured by replacing the front axle locker actuator. I’m still trying to understand how this would cause a vibration only when turning and only when under load.
Could this be something in the rear even though it feels to be coming from the front?
Yeah sounds like its stuck in 4WD. That’s how it sounds when you turn on dry surfaces with 4WD engaged.
Was the vibration there prior to the dealer replacing the front differential and taking the lift off? I'm struggling to understand a way a 2" lift (assuming just a leveling kit) can cause a front differential to fail... Was the diff used or new? Did they replace any other parts like the front axle u-joints?
Also, is it just a vibration or does the truck seem to bind and stop if the tight turn is maintained? The truck isn't in 4wd is it?
If I had to throw something at the wall and see if it sticks, the truck is either in 4wd or one of the front axle u-joints is either installed incorrectly or absolutely smoked.
Yes, the vibration was there both before and after Ram replaced all of the aftermarket suspension and also replaced the front differential and the front axle under warranty. When I picked the truck up from this work, the vibration in tight turns at slow speeds was still there. I knew it immediately from just pulling out of the parking space at the service center. I told the service advisor who was very upset the truck had been released to me without the remedying my complaint, and had the tech go for a test drive with me so I could be sure he felt the problem. The tech could feel the vibration but didn't know the cause only from a test drive. The service advisor then recommended replacing the steering box for $3000. Everything I read about steering box failure diagnostics does not agree with my truck symptoms, so I have not yet replaced the steering box.
So to answer your reply questions, yes, the front differential replaced by Ram was new. And yes, the axle u-joints were replaced and the front drive shaft was replaced so I assume that would include the drive shaft u-joints.
When driving the truck slowly in a tight turn, the truck does not seem to bind or stop. You feel a very noticeable vibration both in the steering wheel and through the floor both on the driver side and the passenger side. The vibration is very much there and the growling noise is faint but definitely there.
No, the truck is definitely not in 4wd (I wish it was that simple!) I have wondered if an axle locker actuator is possibly stuck. I don't know how to diagnose that.
Is the growl/vibration speed or rpm dependent? Does it happen in drive and reverse? Have you pulled the front driveshaft and tested for the vibration?
I would not authorize the steering box replacement either. If you want my honest opinion I would search out another reputable shops opinion. It really sounds like the dealer you are at doesn’t have techs worth their salt - just throwing parts at things.
Find a good independent on Google, take it there and pay them to diagnose it. Then take it back to the dealer for warranty work.
Stock wheels and tire size?
