Very warm center floor tray.
JimKIII
I have the split-bench front seats with the lift-up center console. On the floor in front of the center console is a small tray sitting on the driveshaft hump where I put sunglasses, keys, etc. in.
I picked up something out of that tray the other day and was surprised how warm it is. (This isn't new, I noticed it years ago too.) Things don't get hot where you can't pick em up, but they're noticeably warmer than normal.
Does the driveshaft create enough heat to warm up stuff in the tray?
If it is warm while your heater is on then it is possible the carpet is laid overtop of the rear seat heat ducting. On my 19 I had to remove the tray and straighten out the carpet as it was blocking almost all of the air flow to the center back seat outlets.
Hi @JimKIII!
If this observation is enough to cause any concern for you, we're also available to help if you decide a dealer appointment is in order.
Hannah
Ram Cares
I had an old Jeep XJ that I added some heat shield to the tub on the trans hump because it would get rather warm inside during the summer. I think the factory carpeting and heat shield was so old it losing its effectiveness.
You could add some to the hump under the carpet if you want a weekend project. I know they sell some on Amazon.
