I’ve got everything installed, hardware, software, and it’s up and running. But….
There’s one of two things going on….
The connectivity is extremely sketchy.
I am dragging a 40ft PJ Gooseneck trailer where the axles are back away from the truck around 28-30ft(not 100% sure on the distance. I’ll unroll a tap measure on it an FO)
I think there’s so much metal between the receiver behind the bumper / license plate and the tire sensors it’s creating interference.
If you’re laying under the truck looking up at the wifi receiver, it’s mounted off center to your right or just to the left(driver side ) of center.
This last week on a load run from Austin Tx, to Albuquerque, New Mexico I noticed that all tires at some point did pop up and register on the dash screen. The two that 98% of the time that didn’t show up were the two right outside tire sensors. By a straight line where the sensor is and those two outside tires seems to be the most congested obstruction.
I really do not want to run a 15 or 30 ft jumper under the trailer. I’d have to plug the receiver back into the main harness everytime I switched trailers. Or get a dash error…
I’m going to attempt to relocate that receiver to the bottom of the bumper or possibly outside the bumper next to the plate right above it.
Gonna see IF I can find a location that allows a more efficient constant signal.
Trying to avoid ab extra long relocation cable if I can.
RAM should of addressed this with a booster over the last four years.
Any help or suggestions appreciated.
Thanks in advance.
Pray for Texas
