phatboy64
Here is my 2 cents which is probably worth zero.
If a product such as the kit mentioned above is supposed to make the ride quality better then it should do that without changing air pressure. Changing air pressure should then enhance the already improved ride quality.
To me the message above is a little BS, I mean lowering the pressure to 35 psi should make the ride better without the kit that was installed. That is not a fix.
If it were me and I wanted to get to the bottom of this I would go back to stock as much as possible, get a baseline on ride quality and then start adding stuff one at a time.
If you get back to stock and still have the same issue that you know it is not the kit..
Continuing to throw money at the issue based on other peoples experience or marketing writeups could be a loosing game.
Again my 2 cents...
Again my 2 cents...
