Crusty old shellback
Drove the truck to town. Is a little better. Not as much body roll as it is with the fox shocks. So seems it's the rear suspension causing the issues.
The poly bushings will likely cause a combination of limited flexing, increased vibration transferred to truck/occupants.I thinking to go with the striker adjustable arms I posted at first. I know CJC said stock or Thuren. But the Thuren bars have poly bushings to allow better travel. Granted the bars are longer and they change geometry. But why would poly bushings in stock length bars not work as well?
I thought it was the opposite.The poly bushings will likely cause a combination of limited flexing, increased vibration transferred to truck/occupants.
Dons talking about the vulcanized factory bushings. The bushings are fixed in the control arm and to the center sleeve. When torqued properly, the center sleeve of the bushing is locked in place. The bushing has to physically deform/ twist (torsion) for the arm to travel.I thought it was the opposite.
From Thuren
"One other aspect Thuren has improved is the ride quality and vertical travel. This is accomplished by removing the OEM arms which use Torsion Bushings, which store energy like a spring. The 8 of these OEM Torsion Bushings take quite a bit of force to allow the axle to move 6" up and down. With them now being gone, you have effectively lowered the spring rate. If you tow or load heavy often, this could be undesirable, as you will notice a bit more sag when weighted as you have lost some of that "Torsion Bushing Spring Rate."
I don't really tow anything.
