Caleyvtwin
When it comes time to Calibrate the cameras - that setting is (from the start page in Alfa) in the Radio module, then you select CVPM... (see pic), then switch to the active diagnostic tab, select the options I have in the pic. On your radio, select surround cameras - then start driving at approx 2-8 mph.. then press Start on the test... Your screeen will go green and show a series of arrows, a speedometer, and a steering wheel.. be patient, it takes a minute of driving... Do each camera in sequence. You migh thave to Disconnect/Connect from the CVPM each time.View attachment 68214View attachment 68215
Thank you. I have looked and looked and could not find any information on performing the calibration.
I assume the LED light portion of the CHMSL is plug and play?
