Sport Hood
Lee Iacocca
Grumpy Old Fart
Tennessee
My hood makes a gap above the black plastic piece inserted in the hole when it is hot. Anyone else have this problem? The truck is brand new, not about to let the dealer order a new hood and paint it to swap out.
Checked it cool this morning and same gap, gonna take it out in a while. Your thoughts are that that hood should be clipped to the top of the plastic insert?
Isn’t that where the two bolts go into?
Does the plastic come out under the hood or outside over the hood?
It may have missed a tab on installation. Undo the screws holding it on and pull it out, it’s pretty obvious how it goes back on.
Are you referring to these teeth?
I don’t see anything that could hold it down.
I took the 2 bolts out but did not get the plastic out because it didn’t want to go in either direction, so instead of breaking it I put the screws back in.
Can you physically close that gap with your hand by pushing up on it? If so, slide you a piece of double sided trim tape in there and press it together.
