Is it two pieces, or one?It may have missed a tab on installation. Undo the screws holding it on and pull it out, it’s pretty obvious how it goes back on.
Mine just pulled out. It should be pretty obvious.Anybody here know how to remove this piece after the two bolts are out?
Towards the front?Mine just pulled out. It should be pretty obvious.
Only by pushing down on the steel hood, plastic won’t budge.Can you physically close that gap with your hand by pushing up on it? If so, slide you a piece of double sided trim tape in there and press it together.
