Theoretically you shouldn’t have to watch it. The system should run itself and if there’s an issue, it should generate a code.
That being said, I think it’s important to monitor the gauge to see and understand how your drive cycles have an effect on the number of regeneration cycles your truck uses.
During active regeneration, the engine fuel injectors are commanded to inject diesel fuel in to the cylinders during the exhaust stroke. That fuel is sent downstream to the DOC and DPF and is used to artificially increase the temperature in the DPF above the threshold where soot will be combusted. (Roughly 1,000-1,200°F). Since you have no control over when these active regens start, it’s helpful to try and time them to when your drive cycle will allow the most ideal operational conditions for maximum regenerative effect.
An active regen cycle that is run while doing stop and go, or low speed / low rpm / low load duty cycles is less effective, and can also lead to increased fuel dilution in your engine oil since the fuel is sprayed into the cylinders. (Some of that fuel makes it into the engine oil, especially if the truck is running low rpm). There’s also a chance that the cycle will not fully complete, thus not completely removing the soot in the DPF. If this continues to happen, the soot-loading in the DPF will continue. When it reaches 80%, you’ll get a pop-up warning and a chime, telling you the regen needs to happen and you need to keep driving.
If your truck does a lot of low speed / low load work, you’ll end up running more regeneration cycles, which leads to more fuel in the oil. If this is the case, you really should be cutting your service intervals down.
Watching the gauges helps to better understand what your truck does, and how you can match your operation and maintenance procedures to best maintain the truck.
