Just making this thread as reference for people. Mods can sticky it maybe?
I compiled a list of armor(skids, sliders, guards) that fit 2019+ Power Wagons, in addition to or as replacements to the factory underbody armor (crossmember, fuel tank skid plate, transfer case skid plate, 3-bar transfercase/driveshaft/exhaust guards).
If you know of more, post them and I’ll add it in.
I might add front bumpers since would be PW specific and there’s not a ton of options, but I’ll leave off rear bumpers since any HD rear bumper fits and there are tons of options.
Updated 5/13/2025
Rocker Panel Protection/Rock Sliders
Dethloff Mfg XHD Rock Sliders
dethloffmfg.com
White Knuckle Offroad Rock Sliders
white-knuckleoffroad.com
Rocky Road Outfitters Rock Sliders
rocky-road.com
TNT Customs Expedition Series Rock Sliders
tntcustoms.com
Randy Ellis Designs “Sleekster” Rock Sliders
Mopar OEM Rock Rails (PN: 82216580AA)
Underbody Protection/Skid Plates
Dethloff Gen 2.0 HD Engine/Transmission Skid Plate
dethloffmfg.com
Dethloff "3-Bar" Replacement Skid Plate
dethloffmfg.com
Dethloff Transfer Case & Evap Skid Plate
dethloffmfg.com
CJC Offroad Winch/Intercooler Guard
www.cjcoffroad.com
SDHQ Winch/Intercooler Skid Plate
sdhqoffroad.com
Vice Designs Defender Skid Plate
www.vicedesign.ca
Differential Guards/Heavy Duty Covers
Carli Front Differential Guard (1/4” Steel)
carlisuspension.com
AEV Front Differential Cover (Nodular Iron)
www.aev-conversions.com
Purple Cranium Spider Rear Differential Guard
AEV Rear Differential Cover (Nodular Iron)
Misc
SDHQ Rear ABS Guards
sdhqoffroad.com
CJC Offroad Rear Shock Guards
www.cjcoffroad.com
Dethloff HD Rear Shock Guards
dethloffmfg.com
No Longer Available (For Reference)
Maple Offroad Rock Sliders
Maple Offroad Front Differential Guard (3/8” Steel)
Maple Offroad “3-Bar” Replacement Skid Plate
Maple Offroad Front & Rear Skid Plate Cross Bar Replacements
Dethloff Oil Pan/Transmission Guard (2019-2020 Only) [Gen 1]
Godz Mfg Intercooler Skid Plate
Godz Mfg Transmission & Oil Pan Skid Plate [Aluminum]
Godz Mfg Power Wagon Skid Plate System [3-Bar & Transfer Case Guard Replacements - Aluminum]
Updated 5/13/2025
XHD Rock Sliders: 2014+ RAM 2500/3500 | Dethloff Mfg
***FREE FREIGHT SHIPPING*** Now in production: estimated build time ~ 6 weeks
dethloffmfg.com
RAM Power Wagon / 2500 / 3500 2019-Newer Rock Sliders - White Knuckle Off Road Products
ram-power-wagon-2500-2019-newer-rock-sliders
Ram Power Wagon Rock Sliders: 2019-2025 Power Wagon Step kit
RAM Power Wagon Rock Sliders. Undisputed best on the market in design, ease of install, strength, and utility... from Rocky Road. Great for step use!
rocky-road.com
Ram Power Wagon Sliders
Ram Power Wagon Expedition Series Rock Sliders feature rugged construction and sleek styling, giving our sliders a one-two punch. Our rock sliders are designed for wheeling. Constructed with 4 Support feet mounted directly to the frame, 2″ x 2″ x .25″ square tubing 3/16 plate, and 1.75 x 120...
tntcustoms.com
2500/3500/Power Wagon RAM Crew Cab Rock Sliders Body Armor #ROCK3405(T)
Light bars, LED Mounting Solutions, Rock Sliders, Mud Flaps, Battery Boxes and accessories.
www.randyellisdesign.com
HD Engine-Transmission Armor: 2014+ Ram 2500/3500 | Dethloff Mfg
Severe Service protection for your Hemi or Cummins powered HD Ram 2500 & 3500.
dethloffmfg.com
3-Bar Skid Plate: 2014-Present Power Wagon | Dethloff Mfg
dethloffmfg.com
Transfer Case & Evap Guard: 2014+ 2500/3500 | Dethloff Mfg
dethloffmfg.com
CJC Built 2019+ Ram 2500/3500 Skid Plate Intercooler Guard
CJC Built 2019+ RAM 2500/3500 skid plate Intercooler guard will eliminate the weak plastic front bumper valance that is supposed to protect your intercooler in your 2019+ Ram 2500/3500 Cummins with the CJC metal Intercooler Guard Skid Plate. These require no drilling or modification to fit!
www.cjcoffroad.com
'19-26 Ram 2500/3500 Powerwagon Skid Plate System
PRODUCT OVERVIEW: Our SDHQ Built 2019-2026 Ram 2500/3500 HD (including Power Wagons) Skid Plate System is designed and manufactured with precision, using 3D CAD technology for an OEM-quality fit and finish. This system, designed specifically for trucks with stock bumpers, is made from heavy-duty...
sdhqoffroad.com
Defender Skid Plate System | 2019-2026 RAM 2500-3500 | 5th Gen
Removing the vulnerable plastic valence on your front bumper gains you almost 7" of front ground clearance, but it comes at a cost. Not only does it look unfinished, it exposes vulnerable components, especially to RAM 2500 & 3500 trucks equipped with the 6.7 Cummins Engines. Our Defender Skid...
14-22 RAM 2500/3500 4X4 FRONT DIFFERENTIAL GUARD
This is one of those things that you should have before you find out you needed it. Being that the OEM front differential cover is soft steel and the lip is vulnerable to even slight impacts on rocks, installing our Differential Guard will give your ring and pinion a solid steel shield should a...
AEV Front Differential Cover for 2014+ Ram HD
The 2014 Ram 2500/3500 front differential cover features a vehicle specific fluid level verification port to avoid the need to guess on oil level. Order now!
Dodge AAM 11.5" Full Spider Rock Guard
Dodge AAM Spider Differential Guard 11.5" RG for 2500 & 3500 2003-Present...yes the Power Wagon, over 60 different colors, protection that looks great and works...
purplecranium.com
AEV Rear Differential Cover for 2010+ Ram HD
Equip your 2010+ Dodge Ram 2500/3500 with AEV's rear differential cover. Designed for maximum strength, this cover ensures top performance and longevity.
Misc
'19-24 Ram 2500/3500 SDHQ Built Billet Rear ABS Guards
Protect the rear ABS sensors on your 2019-Current Ram 2500 and Ram 3500 while off-roading and from road debris
sdhqoffroad.com
CJC Off Road Ram Rear Shock Guards
Protect your shocks with our CJC Built shock guards. These steel shock guards use your existing lower shock hardware to easily bolt in place and add much needed protection for 2014+ Ram 2500 trucks, 2003 to 2012 Ram 2500 trucks, or 2003 to current Ram 3500 trucks.These guards come coated in...
www.cjcoffroad.com
HD Rear Shock Guards: 2014-26 Ram 2500 | Dethloff Mfg
***Fits 2014-Present Ram 2500 True, HD protection for the aftermarket shocks on your Ram 2500! Unlike any of the light-duty gravel guards on the market, these skid plates offer robust 3/16" steel construction with a stainless steel impact face to keep wear & impacts from turning your shocks or...
dethloffmfg.com
There are two "scab plates" welded on the frame that block installation. I went through this with Marcus and he has to redesign it for the 21's. I actually had one shipped to me and had to return it. I was very tempted to see what I could figure out while I had it in hand.
