Are you planning to make that dreaded trip to a dealer?Mine just started doing this in the last week and I've had it since august. I do recall my older Rams, 2018, 2017, 2014, doing something similar when turning over bumps and dips. To me it really gave it a cheapness factor when comparing it to a F350 that I had which didn't do that.
I had to switch my appointment to Tuesday, so I'll get on here and let everyone know what they tell me. I'll assume nothing will be able to be replicated.
What else is new?Dealer checked it out and couldn't replicate it. They had it up in the air on the hoist and said everything checked out, nothing loose, etc. Tech took it for a drive and nothing.
The audio is terrible and they are 2014 trucks.. but heres a visual on how bad the ford frames are...It seemed to appear the last time they stiffened the chassis, which may have been the 4th Gen rollout. I don't like it, but watch a Ford go over uneven terrain, and see the frame flex like a bungee cord.
They did the same thing with mine. I have found the sharper I turn going into an incline is when it happens. Colder weather seems to affect it. Dealer said good not replicate.Dealer checked it out and couldn't replicate it. They had it up in the air on the hoist and said everything checked out, nothing loose, etc. Tech took it for a drive and nothing.
I have the same problem. Were you able to get this fixed and if so what was the solution.2019 3500 Limited cummins....On tighter left turns and any turns over a bump or dip, I am hearing a clunk and popping noise from the front end on the drivers side. Im thinking ball joint or something suspension wise.
Same thing here. Mine is on right side. Usually happens turning right onto decline like into my driveway.I have the same problem. Were you able to get this fixed and if so what was the solution.
Thx
