Persistent App Market Notification?
Pilotib
Has anyone else been dealing with a stuck notification for the completely useless App Market? It showed up somewhere around a month ago, and I cannot find any way to get rid of it. I know that for some, going to the “Home” button and then back to CarPlay can clear it, but that does nothing for me. I have done the tune/volume hold for a reset, and also the hard reset which loses all my settings. This still did nothing. I have a case number with Connected Services, but they have been absolutely no help so far.
To get ahead of the “Why worry about it?” crowd, it is highly annoying as that notification blocks the song or channel listing which apparently I look at far more often than I had realized. Additionally, it seems that the system has overall become far more “glitchy” since whatever the last over-the-air update was that caused all of this in the first place. It seems that CarPlay is the least happy, as half the time it is slow to launch or just fails completely. At that point, I have to pull over and shut the truck down and open a door to get the system to reset. If I take it to a split screen, the bottom of the map is fuzzy, and will not allow me to select any of the needed buttons where that fuzzy area is.
Connected Services says that they don’t know what to do, and that I should just wait and hope that an update comes out that fixes it at some point. This is a wholly unacceptable answer. They also claim that this is not a widespread thing, but I wanted to verify that myself by reaching out to all of you fine folks. And just for good measure, I figure that @RamCares should be in on this conversation.
We appreciate the tag and feedback. At the current, there is not an option to remove the widget. However, we have documented this and will relay it for a comprehensive review with our dev team! Thanks for sharing.
Chris,
Ram Cares
I assumed that was a permanent soft key to always be able to access the app store that literally no one wants. I don't use the connected services whatsoever and ignored the dealer talking about it, never have and never will set it up.
I didn't even know any other information showed up there, that icon has been there since day 1.
It just popped on on mine too. Very annoying. Who asked for this? I wish they would just leave us alone.
Chris, (Ram Cares)
This is not an acceptable answer. You have added completely useless bloatware to our systems when they had been running fine, and certainly without consulting your users. Now we not only have an annoying button that NOBODY wants, (nor will it ever be used) but it seems that the stability of the entire system has been badly compromised. Did you task your latest intern with “driving engagement within UConnect” and this is what they came up with? Stupid ideas like this are what drive otherwise happy customers to other brands. Ram does not actually care, and schemes like this seem to back that up. You need to do better, and you definitely need to fix this.
Ryan
Chris,
Ram Cares
