F3arl3sslimited
Has anyone thought about/looked into the ability to put the passenger screen from the new 1500s into the 4.5Gen 2500s?
Yes. It will fit, but that’s all I know for now until I can get my hands on one. Most likely need a 2023+ UC5 radio module. I already tried a wagoneer passenger screen in a 2500, and wouldn’t fire up, but that could have been because the Ethernet ports are inactive on the 2022 radio module I tried it on.Has anyone thought about/looked into the ability to put the passenger screen from the new 1500s into the 4.5Gen 2500s?
Won’t know any more until I get my hands on a screenIf the ports are there, do you think it would be as simple as a flash/software update the '23 to enable them?
If it allowed you to screen cast movies, my wife would love it!From what I can tell, it is interactive with the main screen (map etc, but also seems to have an HDMI input(maybe even screen share) for the passenger to be able to use as a screen for movies etc. it is where the upper glove box is. It is currently in the 1500s
Sounds like permission to order a 25 if it has the screen.Yeah, that is why I asked, my wife saw it on a Ram commercial and asked why we didn't have that.
I’ve had one for a while now, but it’ll be extremely difficult, if not impossible, to make it work in a pre-2025. It uses a separate button to turn it on, which is on a linbus message that pre-25’s don’t know. Then once we figure out how to turn it on, there are settings that need to be in the radio to give the passenger permissions to use the screen. Those radio settings only exist on the Atlantis high architecture.I have a new passenger screen if anyone wants to test if it will work on 1500 and 2500.
So it is impossible to make it work in previous yearsI’ve had one for a while now, but it’ll be extremely difficult, if not impossible, to make it work in a pre-2025. It uses a separate button to turn it on, which is on a linbus message that pre-25’s don’t know. Then once we figure out how to turn it on, there are settings that need to be in the radio to give the passenger permissions to use the screen. Those radio settings only exist on the Atlantis high architecture.
It’s basically the equivalent of trying to get a BMW instrument cluster to work in a Ram truck.
It won’t be plug n play. It’ll need a custom harness added. The bcm will need to be configured for it, and proxi alignment performed. There’s currently no way to do that.Thanks for the offer. I'm probably a few weeks away from pulling the trigger on the truck yet. Do you know, or do you have some level of confidence that this would plug right in and work?
do you still have it?If you are looking for the screen, I have it and I can also get you the bezels that surround it.
