I don't see how they can say that's normal! Losing a quart every 2,500 miles is normal? I call BS on that. I've got over 16,000 miles on mine now, four oil changes (the first at 500 miles just 'cuz) without a perceptible loss of ANY oil.
If you're losing 1qt/2,500 miles, how much was lost after your 500 miles 'test' - 1/5 of a quart? I'd recommend taking your truck to another dealer, print out the msgs on this board from folks who have zero oil loss and become a squeaky wheel.
So an engine with a near 60% oil loss (57.14% to be exact) every 4,000 miles (less distance than between oil changes!) is acceptable, eh? What a garbage motor that would be. No one would buy a rig with that crappy of an engine in it. Even if its only, "under a certain mileage". During my near 70yrs on this planet I've had two vehicles that lost oil that bad. One was a 1960 VW bug that I had stripped the drain plug, the other a 1958 Ford sedan V8 with blown rings. None of those two were 'acceptable', but back then no one cared. Gas was $0.32/gallon and cigarettes were $.40/pack from the machine in every gas station lobby. Ah the good old days.....Dont quote me on this but iirc, its 1qt for every 1000 miles under a certain mileage is considered acceptable. If that is true, i guess its "normal".
But i do plan to try another dealership to see what they say.
Oem spec, of course.What kind of oil are you guys using, to get that kind of oil loss?? I have a 2018 Wrangler that would consume approx 1 quart every 5k miles. It used 0w-20, full synth. A while back I switched to a heavier 5w-30 full synth, and it has been fine ever since.
Recently GM has quietly encouraged owners of their gas trucks to switch from 0w-20 to 0w-40 oil to solve several issues, including bearing issues. The lower weight oil is great for meeting CAFE Standards for mileage, but it is crap for engine longevity.
Yep that PUP 0w-40 works good.Oem spec, of course.
Assuming this is a 6.4 you are talking about. There is always going to be oil in the intake stream as that's where aerosolized oil gets dumped via the PCV. Generally, should be anyways, very small amounts.Hello All. I'm noticing blue puffs on startups. I don't drive every day and it's a 2021 with 47,000 on it. Lite to no heavy towing. Lots of highway time. Use PUp and Mopar filters and never go below 30% oil life or over 5000k miles. I'm about to monitor the level here every 500 miles, but not happy seeing blue puffs. Its oil in those cylinders or the intake stream. Not happy at all!!!
Do you drive short distances? Or more highway type of driving? Having worked in a dealer (years ago) we had a few customers that made small commutes that never really got the engine/exhaust hot enough to burn off build up oil/gas from constant cold engines. It caused a bunch of driveability issues. I would take a nice long drive (a few hundred miles) and don't be shy once in a while (like merging onto the highway) with the throttle. Sounds like it needs a romp with the skinny pedal to clear it out. Typical the scenario I'm imagining would be black smoke, but sometimes the colors aren't clear. Just my $.02Hello All. I'm noticing blue puffs on startups. I don't drive every day and it's a 2021 with 47,000 on it. Lite to no heavy towing. Lots of highway time. Use PUp and Mopar filters and never go below 30% oil life or over 5000k miles. I'm about to monitor the level here every 500 miles, but not happy seeing blue puffs. Its oil in those cylinders or the intake stream. Not happy at all!!!
How many miles between oil changes do you usually drive?So I have 61000 miles on my truck and I know it is due for another oil change as I am dropping it off at the dealer this coming Tuesday. But yesterday, I remote started the engine and while I was walking up to it I heard the rockers knocking for a few seconds and then it stopped. So I checked my oil level and I noticed that I was below the low level line on the dipstick. Even though the oil is being replaced next week, I still added 2 quarts of oil to make sure it was topped off. I will bring this up to the dealer when I drop it off to see what they say. Hopefully it was just low on oil.
