Are you accessing JScan customer service by any means besides Facebook?I routinely change my TPMS set points. JScan makes it easy with a great interface. Also recently recalibrated my dually’s rear air suspension. Great customer service as well. Can’t be beat for the price.
I also saw there’s a setting for the TPMS percent of that point to turn on and off the light. You have to go into the modules and BCM tab. I haven’t tried to mess with it but if you need a wider range for TPMS that might help.I routinely change my TPMS set points. JScan makes it easy with a great interface. Also recently recalibrated my dually’s rear air suspension. Great customer service as well. Can’t be beat for the price.
Will check it outI also saw there’s a setting for the TPMS percent of that point to turn on and off the light. You have to go into the modules and BCM tab. I haven’t tried to mess with it but if you need a wider range for TPMS that might
Facebook and send him direct messagesAre you accessing JScan customer service by any means besides Facebook?
I don’t have FacebookFacebook and send him direct messages
That would be cool to avoid having to switch pressure thresholds.I also saw there’s a setting for the TPMS percent of that point to turn on and off the light. You have to go into the modules and BCM tab. I haven’t tried to mess with it but if you need a wider range for TPMS that might help.
[email protected]I don’t have Facebook
I got the tank size adjusted. Easy peasy.There doesn’t seem to be any one master thread for jscan. If you search “everywhere” for jscan it comes up often in other threads but no 1 stop shop for all things jscan yet.
I also just got jscan for my 2023 power wagon, and only regret not getting it or sooner. So far I calibrated speed by changing tire size (do this on level ground as it often seems to require an abs initialize to fix the many error lights that come with changing tire size), changed TPMS set points, turned on gear indicator (requires setting to be turned on from dash after selecting “active” on jscan… I’m not proud of how many times I selected active before I did some digging and found it activates the dash setting to enable it to be turned on and doesn’t just turn it on automatically), and disabled fog lamp drop out (keeps fog lights on with high beams).
There’s so much more jscan can do but that was all within the first hour of having it.
It’s also important to note the need for the security gateway bypass cable on any 2018 and newer vehicle. I used the OBDLINK MX+ it’s the most expensive option but also seems to be the most full proof when it comes to working with whatever vehicle you plug it into. A license is needed for each VIN you want to make changes too.
Tank size was on there I do remember seeing it, just didn’t mess with. Should be easy to make the changes. The app has a really nice demo mode that lets you look at all the options, and the search feature works well if you look up “tank” it will bring up the setting you are looking for.
Is there a tutorial on how you did all of these? I got my bypass cable and vLinker MC+ from a fb member. I tried changing the tire size and tpms threshold but got a lot of errors. I reset all of my settings and got a lil discouraged.There doesn’t seem to be any one master thread for jscan. If you search “everywhere” for jscan it comes up often in other threads but no 1 stop shop for all things jscan yet.
Select DJ for the 2013 and newer 2500s see attached picture.Is there a tutorial on how you did all of these? I got my bypass cable and vLinker MC+ from a fb member. I tried changing the tire size and tpms threshold but got a lot of errors. I reset all of my settings and got a lil discouraged.
Also, what vehicle did you select? I thought our trucks are DT body style but the only option were for the 1500s.
Thank you. When changing the tire size, how did you get rid of the warning lights?Select DJ for the 2013 and newer 2500s see attached picture.
I have NOT done that, but I think it is ABS initiation or something like that.Thank you. When changing the tire size, how did you get rid of the warning lights?
Your original post stated you calibrated the speed by changing tire size. I tried doing it but got warning lights on my dash and restored the settings.I have NOT done that, but I think it is ABSOLUTELY initiation or something like that.
Sorry I only meant the gear indicator and TPMS.I have NOT done that, but I think it is ABSOLUTELY initiation or something like that
