Night Edition Headlights
Doc Fluty
I have a 2020 power wagon and was interested in swapping out my current led lights for the 2021 Laramie night edition version. Would those lights be plug and play with my power wagon reflector leds? Im not interested in any turning features... just as long as the low, high and blinkers work as expected
I believe these are the part numbers: 68360183AB - 68360182AB
Thanks for any help you can give
No, the new Laramie night edition has this blacked-out style with the single DRL line rather than the dual DRLs that the power wagons have.. also notice the four leads in the headlight rather than the reflector the PWs use.
Also, you can read about them here
Sorry, I thought they were simply laramie versions because when I go to build a truck and click laramie then these come standard, albeit the chrome versions.
Would a dealer be willing/able to program them?
I've disconnected my ground a few times while wiring up new 12v items and sometimes the truck acts funny when I reconnect it... like the backup camera doesn't work or something like that... usually I have to wait 24 hours and it all fixes itself.
If the dealer has to flash the truck to make the lights work I'm worried that if I need to disconnect the battery again I would then lose my headlights until I get to a dealer to reflash them... which could be problematic and troublesome.
The lights you show are the Adaptive Directional projector LED lights that come on Limited models and were included on the 75th Anniversary PW (shown) and are available in the Level 3 package PW.
Wat. The online builder shows chrome LED reflector headlights on Laramie.
If you want to swap your current headlights for the ones you have pictured, you will need a custom conversion harness. They are not a direct plug n play swap. The dealer will not be able to program them, so you’ll have to use AlfaOBD to get the lighting features to function 100% like factory. Since you would need AlfaOBD and a conversion harness anyway, you would also just use AlfaOBD to turn on the adaptive feature, too, otherwise the turn signals won’t function correctly.
Thanks for the info. This is actually one of the reasons I am thinking of selling my PW and going to an older Defender.... these new vehicles just don't let you do simple things simply.
I put a set of seats in my challenger and it shut off the airbag system... now I'm just trying to swap headlights just to a different trim level and it turns into an ordeal.
This is so frustrating... thanks again.
Yea that makes sense buy a Land Rover you’ll have less problems lmao
Yeah, but when something goes wrong it’s easy to diagnose… you can add axles, gauges and more and it doesn’t mess with computers
If it was just a simple headlight swap, it would be straight forward. However, the projector headlights might as well be from an entirely different vehicle. They’re directional and turn with the truck. Something has to control them.
You’re wanting the “tech” headlights without the tech.
It's not frustrating if you do a little research first instead of just throwing parts at something then complaining after finding out there's more to it.
These new vehicles are rolling computers, you don't think that's going to take some code settings changes or wiring changes for adding different parts?
I don’t understand how you are essentially trying to cross shop a brand new Ram with an older Defender. They are not in the same category at all.
The Defender might be more capable offroad and simpler to work on; but it will be slow, noisy, and much less comfortable on road.
Everything is compromises. Do your homework, find a balance, understand limitations.
If I were interested in doing this, would the headlights be the part numbers listed in the first post? The 2 Canadian sites I looked at had those 2 listed as discontinued. And would the custom conversion harness just be for different wires between the headlights and BCM or something similar? Would my 2019 2500 bighorn have the correct circuits ran to accept the new harness or would it be more involved? Thanks for the help
The parts listed in the first post are for the projector adaptive headlights with black housings. They may have been superseded with new part numbers.
The conversion harness is needed because those headlights have different connectors, and adds all the missing circuits. It will work on any trim level 2019+ Ram HD.
Its not frustrating just a couple extra small steps…
Land rovers are frustrating
Do you have a write up on this swap? I’m considering (if the cost isn’t too painful) swapping Laramie LED reflectors with Limited LED Projectors to get the night edition headlight.
Here’s a link to a thread where someone explains how to install them and run the harness.
