New Ram 2500 Leaks
TexasHD
Texas
I'm noticing these small oil stains on my concrete driveway. Slid under the truck tonight with a flashlight and found the transmission is leaking along the seal of the housing and also the transfer case is leaking. 517 miles on the truck. So sad, so disappointed. I guess this why Stellantis sales are so poor.
Belittling other members will not be tolerated. Be helpful or be gone.
I'm noticing these small oil stains on my concrete driveway. Slid under the truck tonight with a flashlight and found the transmission is leaking along the seal of the housing and also the transfer case is leaking. 517 miles on the truck. So sad, so disappointed. I guess this is why Stellantis sales are so poor.
Idk whats worse you thinking RAMs sales are poor or the fact that you think the differential is a trans or transfer case.
the pinion seal is sweating but thats not an active leak that would leave a mark on your driveway. There is a reason for warranty and the 2024s seem to be common for t case output shaft seal issues
Did you wipe this area down to see if it comes back? That could be some kind of assembly lube, hard to tell from the pic. That’s pretty far forward to be a leak, IMHO.
Could be timing cover.
I think you’re snide remark to people who might not be as knowledgeable as you is what’s worse here. No it’s not dripping but the transmission is at each of the three visible bolts. There were drips there but I wiped them away.
Any pics of the actual trans then? Was the fluid red? I could just be oil from the engine making its way back.
PS sorry if you got offended about my previous post…… i was put on forum timeout for 3 days for it :(
Regarding the oil leak, took it to the dealer today. They said they’d get right on it and gave me a loaner. I had to go back to retrieve something out of the truck and they already had it on a lift.
What dealer is that?? With that kind of response you must be kin. lol
That's not bad. Leaky plug isn't something they can really test at the factory anyways. Sheeeit, even the best engine builders in the country deal with leaks.
You’re very lucky to get a loaner. If you’re bored read a few of my posts. I’ve never been given a loaner yet. Stick with that dealer!
I had so much trouble with a loaner. The MOPAR extended warranty is supposed to cover it but they say there are no loaners available. What is the point of making a perk of the warranty be a loaner car if there is insufficient amounts kept around? Anyway - after they determined it would be about 2 months of my truck in the shop for warranty work (I think 2 months at the minimum that is) they sent me to a nearby dealer that is also owned by the same group and gave me a loaner. You might want to ask if you can get one from a cheaper brand of car (my loaner is a Toyota).
In Texas, from how I read it, if your truck is out of service for 30 days you are entitled to a lemon law buyback unless they offer you a loaner. My dealer’s policy is that they don’t have loaners but when I told them I needed one they just pulled a new truck out of inventory and just gave it to me. I had it for 5 days.
Concerning my oil leak, I got my truck back Wednesday, Oct 2nd.
FROM THE INVOICE:
Fluid Leak Concern (Customer states oil leaking from front end of vehicle)
Tech 753 confirmed concern, determined source of engine oil leaking from right rear cylinder head core plug. Added bearing mounting sealant, reinstalled plug, cleaned affected area of oil, set oil level to spec, test drove vehicle, verified repair, no return of fault.
I will say that from the purchase all the way through the warranty service, I received nothing but courtesy and respect from the team at Blake Fulenwider Automotive in Clyde, TX. I was called sir at every turn and everyone always greeted me and spoke to me with a smile. They furnished a loaner for me right off of the new car lot without batting an eye. I recommend them highly.
Some dealers are just better at being better, that's for sure.
FROM THE INVOICE:
I appreciate the kind of service you received as well. The most noteworthy to me here is they kept it simple. A little sealer on the plug and you're back in business. I've had dealers replace major components and tell me its the only way they can fix things...
