WarrenD
Is your case wet? As in like the fluid had been leaking down the side of the case.If the T-case seal is found to be leaking, is it ok to continue to drive the truck until it can be fixed assuming 4wd is not used and the leak isn't so serious that the T-case runs dry? I would think so, which is why Im a little confused as to why some of you fellas are leaving your trucks at the dealerships and driving loaners while waiting for the back-ordered seal.
My case was also wet, I used a couple of cans of parts cleaner on it, fingers crossed it stays dry.
