Mud Flaps
Anyone gone with the molded OEM mudflaps yet? Due to product image inconsistencies in their listings (e.g. interchangeable re-use of the rubber flaps in the molded flaps listings), I'm struggling to effectively differentiate between them. Ultimately, I'm looking to get front & rears for the truck in my signature (2020 Laramie/Night Edition).
Which of the below are considered most comparable to the molded weathertech's?
Cutting & pasting directly from:
a) Splash Guards, Front, With Flares
Part Number: 82215928AB
b) Splash Guards, Molded, Front, Deluxe
Part Number: 82215923AB
c) Molded Splash Guards
Part Number: 82215926AB
d) other?
Anyone put any mud flaps on for 2500 with 4x4 package with 35x12.50 tires and (stock fender flares)? Did you have to drill new holes? Any issues with turning (full turn) on the front wheel catching the mud guard?
I just put Husky front/back on mine....2020 2500 4x4 with flares.
Perfect fit but not sure of YOUR tire size.
Part number and where did you source them?
I don't have that size....but i did install Huskys flaps on stock and love them.
Scored my Duraflaps today at the factory in Medford OR. The most friendly folks you'd ever want to meet. My 4the set I've bought over the years. They asked me to pass the word if I knew anyone that bought a new Ford F150. A free set of mudflaps installed. They need to take measurments and program the computer to cut pattern for the new model. Somebody will get lucky. They gave me a pretty good deal as a repeat customer/forum member.
Do you know if you order the ones for a truck with fender flares and put them on a truck without would it give you more coverage than one made for one without flares? I assume they just shift the mounting holes out a little bit. asking due to having a smaller offset (+12) wheel that pushes my tires about 2” outside the fender.
I assume you are correct. But if you call them @ 541 245 9148 I'm certain they can answer the question.
Installed Weathertech front and rear splash guards today. Hoping they hold up to these Northern New York lake effect winters. Took me an hour because ....well it’s just the way I am....very particular.
^^^ Have those waiting for the truck I don't have....
Just put a set of these on myself. Perfect fit, uses factory hardware. Less coverage than other brands, but I took the minimalist approach on these.
Do you have any other photos of your truck posted?
I am really happy with mine too.... get some stainless screws instead of the plastic rivets
My only hope is when i put flares kn my truck i can reuse the non flare option ones
Is the hole that requires the drilling the inner most where it attaches to the wheel well liner or was it multiple holes per flap?
