Considering this is a gas motors, diesel comparison seems null. Lower temps = less detonation, longer oil life, and several other benefits especially when towing. Just curious if there are any option other than the stock 216* thermostatModern Diesels are designed to run hotter Why would you do that ? Back in the day diesels ran at 180 .
Didn’t realize you were talking gas .Considering this is a gas motors, diesel comparison seems null. Lower temps = less detonation, longer oil life, and several other benefits especially when towing. Just curious if there are any option other than the stock 216* thermostat
Coolant temp has relatively little impact on combustion chamber temperature. If you’re worried about detonation, more octane is your friend.Considering this is a gas motors, diesel comparison seems null. Lower temps = less detonation, longer oil life, and several other benefits especially when towing. Just curious if there are any option other than the stock 216* thermostat
Only thing I can find is for an actual thermostat or housing is for the newer 1500s not for a 2500 gasser.I've been wrenching for over 50 years myself.
In the old days, yea, you wanted to run a 170 or 180 T stat.
But with modern synthetic oils, coolants, better materials, it's no longer needed.
But a quick Google search pulled up a bunch.
Mishimoto has them.
The aftermarket is never shy about cooking up a solution to a problem that doesn’t exist.I've been wrenching for over 50 years myself.
Mishimoto has them.
Its not a problem and I never said it was. I just prefer to not see 220f coolant and oil temps.The aftermarket is never shy about cooking up a solution to a problem that doesn’t exist.
It’s clearly a good business model.
Just because you’ve been doing it a long time doesn’t mean you know what you’re talking aboutFolks, ive been working and wrenching on cars since I was crapping my diaper. I understand how heat impacts an engine. Coolant temp has a direct correlation with oil temps in these engines. 220F is on the warmer side of where id like to be. I appreciate the information you guys are pushing but id just like to know if there are any lower temp thermostat options that I haven't been able to find yet. Lower temps = less thermal stress on every component of the motor.
It’s the gas engine sub forumDidn’t realize you were talking gas .
Id like to think i know a thing or two about hemis since ive been building and racing them specifically for quite a while. If you dont have anything to add other than attempted jabs, keep it moving. Not here to bicker, just looking for information on parts.Just because you’ve been doing it a long time doesn’t mean you know what you’re talking about
What about 220 degree coolant and oil temps is bad? Genuinely curious what you have to say.Its not a problem and I never said it was. I just prefer to not see 220f coolant and oil temps.
