Lower Temp Thermostat
trizzle
Howdy folks!
As the title says, are there any options for lower temp thermostats? I see they come as a whole housing + thermostat. Would like 190 or below if I could. Thanks!
I will be tuning the fans for the lower temp also.
Modern Diesels are designed to run hotter Why would you do that ? Back in the day diesels ran at 180 .
Considering this is a gas motors, diesel comparison seems null. Lower temps = less detonation, longer oil life, and several other benefits especially when towing. Just curious if there are any option other than the stock 216* thermostat
Didn’t realize you were talking gas .
Coolant temp has relatively little impact on combustion chamber temperature. If you’re worried about detonation, more octane is your friend.
Your synthetic engine oil is tested at 300 degrees, and sees temps much higher than that in the rod & crank bearings. It is right at home in the heat.
You also want to get the oil up to operating temp as fast as possible and keep it there for a while to burn off/disapate any water/condensation there may be in the oil
As mentioned, these engines are designed to run hotter than old engines were. They can do that because the oil is much better and the manufacturing tolerances are much better.
They run hot to increase efficiency and reduce emissions.
If you’re really curious about the physics read about Carnot’s Law.
As others have said don’t worry about the “high” temps. The whole system was designed for it. Ample quantity, flow and heat exchanging surface area coupled with 21 PSI keeping the boiling point high makes for a very efficient and more than sufficient cooling system.
The Hemi may have a couple somewhat inherent problems - the cooling system has never been one of them.
Go changing one aspect of a powertrains design and be prepared to reengineer the whole thing.
Folks, ive been working and wrenching on cars since I was crapping my diaper. I understand how heat impacts an engine. Coolant temp has a direct correlation with oil temps in these engines. 220F is on the warmer side of where id like to be. I appreciate the information you guys are pushing but id just like to know if there are any lower temp thermostat options that I haven't been able to find yet. Lower temps = less thermal stress on every component of the motor.
I've been wrenching for over 50 years myself.
In the old days, yea, you wanted to run a 170 or 180 T stat.
But with modern synthetic oils, coolants, better materials, it's no longer needed.
But a quick Google search pulled up a bunch.
Mishimoto has them.
Mishimoto has them.
Only thing I can find is for an actual thermostat or housing is for the newer 1500s not for a 2500 gasser.
Ive run a 180 thermostat in every single hemi ive had and they've all performed better with it vs stock when tuned for the lower thermostat. Wish they had something to delete the EGR on the gasses too. Took the throttle body off this truck and the backside was caked with crap.
Mishimoto has them.
The aftermarket is never shy about cooking up a solution to a problem that doesn’t exist.
It’s clearly a good business model.
Its not a problem and I never said it was. I just prefer to not see 220f coolant and oil temps.
Just because you’ve been doing it a long time doesn’t mean you know what you’re talking about
Id like to think i know a thing or two about hemis since ive been building and racing them specifically for quite a while. If you dont have anything to add other than attempted jabs, keep it moving. Not here to bicker, just looking for information on parts.
