CoolShocks have arrived and they are indeed 2” shorter when extended than the factory shocks. About 22-3/4” versus 24-3/4”.
GRam, looks like you have a 21 model. Mine is a 23. I'll need to see if they will fit.Shocks have arrived and they are indeed 2” shorter when extended than the factory shocks. About 22-3/4” versus 24-3/4”.
Looks like they do fit. I ordered 2!Shocks have arrived and they are indeed 2” shorter when extended than the factory shocks. About 22-3/4” versus 24-3/4”.
Interesting. I have the same kit on mine. I never noticed any pulling ETC. But, building an adjustable track bar, or converting the factory bar to be adjustable shouldn't be a big issue.When doing the reverse level, has anyone came up with a rear adjustable track bar to re-center the axle. I just installed the Timber Grove 3'' CRM, and the rear axle is pulled to the driver side about 1/2-3/4 ''. The truck also seems to pull to the right a little more than when stock. Just curious if anyone else has noticed this, or have a solution that i haven't discovered yet.
