CharlieL
Very strange - the memory functions for the driver seat and mirrors has stopped working, as well as the "easy exit" seat & auto-dim. About two weeks ago, the "easy exit" seat function stopped working. The seat was in the rearward position & when I got in, it didn't move forward. I tried moving it forward manually & nothing. So I checked the switch moving it backward. Worked fine, but wouldn't move forward. So I drove home (fortunately only about 5 minutes) with seat farther back than normal. After overnight, switch moved things back and forth no problem. However, no easy exit seat - and yes all the settings in the Uconnect are correct. Now I've noticed I have no memory function working. The "set" procedure seems to work ok, but when trying to recall memory for mirrors they don't move. I have done two factory resets and several soft resets. Nothing changed. All other settings are just fine - radio/etc. Also, I have no auto dim for headlights or mirror. Now, the auto dim problem might be my doing. I installed a dashcam & had real problems getting power at the rearview, so may have bent a pin in the connector. Have to check that.....
Anyone else encountered something similar? Any suggestions?...... Thanks....
