elephantrider
Hydraulic Lifter Crew
are you around austin / south central tx by chance? I'd like to put my eyes on those wheels.
torn between 75a beadlocks, and the two aev options.
Thanks! very useful info285/75r17. Specs are 33.9”, measures about 33”.
Stock setup and measurements for comparison:
I believe they would have to prove the wheels/tires caused the failure, although I wouldn't want to fight a dealership over the Magnuson-Moss Warranty Act. What concerns do you have over larger wheels and tires?Anyone gotten denied warranty work because of bigger wheels and tires?
Just wondering. Might need balljoints replaced.I believe they would have to prove the wheels/tires caused the failure, although I wouldn't want to fight a dealership over the Magnuson-Moss Warranty Act. What concerns do you have over larger wheels and tires?
Good looking rig. I had the same wheels on my JLU with 37s Yoko X-AT. Loved that set up.Just installed the 35s today!
Yokohama Geolandar MT G003 - 35x12.5x17
American Racing AR172 Bajas - 17x9 with a -12mm offset, and installed plain black push-through center caps.
This truck handles better with the 35s and with the wider offset wheel-set.
Raceline 18 wheels on 35x12.50 AT BF stock levelWanting to see some Wagons 18+ preferably with 35’s and 37’s on stock or levelled suspension.
NoMy Power Wagon is on order, in D1 status, so no pics to share just yet. Can you can run 37 x 12.50 tires on the stock 17 x 8 rims with the stock suspension without rubbing?
Gorgeous rig!Stock rims and suspension. Nitto Ridge Grapplers 35/12.5/17.
Are you having issues with the beadlock bolts rusting?Stock rims and suspension. Nitto Ridge Grapplers 35/12.5/17.
Man I haven't had any rusting issues, I'm in Mississippi and irs been outside since day 1Are you having issues with the beadlock bolts rusting?
I have the same rims, 9,000 miles on my 2022 Power Wagon, under warranty. Garage kept, in MD. The bolts were rusting like crazy. Stellantis wouldn't replace them. Also, found the wheels to be difficult to balance. I just decided to switch out the wheels when I switched to 35s.
Thank you! Its been my favorite truck.Gorgeous rig!
