Do you have a photo of how your hitch it setup? Is the yellow sticker on the hitch facing forward or aft? Your numbers indicate the pin is aft of the rear axle. With the same hitch I defiantly add weight to the front axle in the furthest forward position.
I come up with 3,400lbs of pin weight. 12,180 GVW with the trailer and 8780 GVW without gives a difference of 3,400lbs which would all be pin weight if the truck had the same cargo/fuel/passengers.
